how did i blow a hole in my valve cover?
i have a spare, but id still like to know how it happened.
this car has not been officially on the road yet, i've just gotten it together, previous problems:
-blown head gasket (white oil)
-cracked exhaust manifold in 2 place
other things i've done/fixed
-all new belts and pulleys on the front end
-new water pump gasket
story:
i went up and down the road a few times and gave it one good pull, it was running fine and i never heard anything go crack, then when i pulled into the driveway smoke started from under the hood and i was greeted with this!
when i did the head gasket i was care full to not remove the buckets from the valve cover, on a side note the oil pressure meter reads maxed out with the light on but i've just been figuring i have the wires hooked up backwards or some silly electrical problem and haven't paid much attention to it.
story:
Basic Sponsor
those inner bolts one probably wasn't torqued correctly and got loose.
well now i feel dumb i was surprised how little torque was spec'd for those bolts
anyway next question,
what do i do about using the buckets out of this cam assembly with my other assembly? The other cam assembly i have does not have buckets and if i can find them they are not marked.
15 Bolts -- I have to count them everytime I pull the cam housing off and put them back on!
I had 14 one time -- couldn't find the 15th.... Pulled the hole assembly off -- only to realize I had put one on the fender and it blended itself in behind some wiring. Doh't
A long afternoon at the shop -- and you should be good to go -- check your oil and filter for debris,
hopefully everything blew out and didn't fall in.
Mike
Mike
I did. What a pain! I replaced the LR cam gasket with a OME one and that fixed most of the leak. Then I found the front Cam seal was leaking
So I fixed that one. So far, so good.
Now I have a noise coming from the right wheel when I turn left. I think it's the bearing. I'll replace them next week end.
Thanks for asking
Thanks for asking
