Pinion and Gear for an AOR Transmission
03-27-2012, 05:32 PM
A friend is looking for this, anyone have these lying around looking for a good home? This is for a 016R Turbo S
03-28-2012, 09:23 AM
So you can expand your search criteria - the AOR R/P is identical to any Turbo 8:27 R/P. Nothing unique about the AOR R/P parts.
03-28-2012, 10:25 AM
Good to know, thanks for that. Sorry for my ignorance but what is 8:27
03-28-2012, 10:47 AM
03-28-2012, 11:30 AM
Rennlist Junkie Forever
Are you looking for the ring gear or both the pinion and ring gear.
I've got several.
TonyG
03-28-2012, 11:48 AM
8:27 is the tooth count (8 teeth on the pinion head, 27 teeth on the ring gear), which equates to the 3.375 ratio.
According to the factory, the R/P are matched sets w/ etched serial numbers, so should only be swapped/installed as a matched pair.
03-28-2012, 12:28 PM
Yes Tony, he needs both, I'll tell him to contact you.
03-28-2012, 12:29 PM
