Lindsey Racing Boost enhancer question....
Yes I know
But.. I have no manual since i bought this one on ebay.
I've read just about a hundred threads about this boostenhancer but did not find the answer.
What is the stock setting? I have a 1986 951 complete stock at the moment just a forge 008 diverter valve added.
Took a picture of what i got and marked it. How much should the distance be? How many threads, looks to be 5 now.
Thanks.
[img]
Thanks.
[img]
The LBE is fine, but only as long as you DON'T use it as a boost controller. It's simply supposed to allow boost to build a few hundred RPM sooner. When used this way, it works and is safe to use.
To the OP, alas I don't know the answer to your question.
Try about .250 inch and go back from there. each turn of the housing equals about 1 lb pressure. its set from lindsey at 10 psi. I found that to be a little high, and was hitting overboost in cold weather.
