"Big Red" caliper part #'s?
Doc
referenced below are the part numbers, If you have a MO30 option you will need the aluminum hats.
PARTS LIST FOR GTS BIG BRAKE UPGRADE
Billet Aluminum Big Brake Adapters
928 GTS Big Black Calipers 928-351-423-03
928-351-424-03
[993 TT Big Red Calipers] 993-351-425-10
993-351-426-10
911 C2 3.6 Turbo Front Brake Rotors 965-351-045-00
965-351-046-00
[993 TT 2-Piece Rotors] 993-351-045-10
993-351-046-10
[928 GTS Front Brake Rotors] 928-351-045-01
928-351-046-01
968 M030 Rear Rotors, Each (2) 951-352-041-91
993TT Front Brake Pads 993-351-949-00
968 M030 Rear Brake Pads 965-352-939-04
993TT Brake Pad Sensor, Each (2) 993-612-368-00
Rear Brake Pad Sensor, Each (2) 944-612-365-01
Brake Pad Vibration Dampers, 44mm, Each (4) 965-351-096-00
Brake Pad Vibration Dampers, 36mm, Each (4) 964-351-096-01
Brake Pad Vibration Dampers, 30mm, Each (4) 964-352-096-00
Brake Pad Vibration Dampers, 28mm, Each (4) 964-352-096-01
GTS Caliper Bolts, Each (4) 900-067-268-02
951S Caliper Bolts, Each (4) 900-067-154-02
Caliper Bolt Washers, Each (8) N-011-564-2
M030 Steel Brake Lines 951-355-041-30
951-355-042-30
M030 Front Brake Hose, Each (2) 951-355-079-31
Rear Brake Hose, Each (2) 944-355-081-01
Clips, Each (4) 914-355-665-00
Front Hub Grease Seal, Each (2) 477-405-641
5/55 Brake Bias Valve 930-355-305-01
5/45 Brake Bias Valve 965-355-305-01
5/33 Brake Bias Valve 928-355-305-02
928-351-424-03
993-351-426-10
965-351-046-00
993-351-046-10
928-351-046-01
951-355-042-30
Doc,
I have converted two cars to the big Red Brakes. I have a 1989/LS3 with MO30, You will need the Big Red Calipers, which will bolt directly to your spindles. In addition you will need rotors, I went with the two piece 993TT rotors, please note you will need to use the Lindsey Aluminum Hats to give you the proper offset.
I believe that TonyG confirmed that the 965 one piece rotors have the correct offset for the MO30 splindles.
Additionally you will need to change the brake bias valve, I have the 5/33 in both my 944's
Max
Max
