Pikington will make saratoga tops Again
Old 05-02-2012, 09:34 AM
  #181
PilkClassics
PilkClassics's Avatar
Price is set at $500 each. Per the schedule, we're running a total of 800 units. There are no plans to run the manual version. The tops will have all hardware and new seals fully assembled. PEvans, if you're referring to the double foam seal on the glass, yes, new ones will be on the glass.
Old 05-02-2012, 09:45 AM
  #182
PilkClassics
Originally Posted by PEvans
PilkClassics, this is a picture of my Saratoga. I think this is identical to the ones you will produce. You can see the seal on mine is totally gone and the movement of the roof has damaged the paint. Is there a chance I could get a new seal from this production run or have you put a new seal on this roof?
Also just talked to the engineer of the project. Yes, you will be able to get just the seal if you don't need the glass. We don't have it in stock yet, but I'm sure once we start the tops assembly in June, we'll have plenty of the seals.
Old 05-02-2012, 09:59 AM
  #183
Bri Bro
Bri Bro's Avatar
Originally Posted by ausgeflippt951
The rear hatch glass has a metal frame that is bonded to the edge of the glass. The hinge/pin hardware is then attached to the frame, not the glass.
Well, the frame tends to separate from the glass (usually up by one, or both, of the hinges) and will cause the most annoying, incessant metal-on-glass squaking you've ever heard.
Even though I never close the hatch with one hand, I have had to reseal it a few years ago and it is already starting to re-separate...
My glass guy said the problem was the primer that is applied to the glass before the glue is put on is separating from the glass. The only way to truly fix the problem is to cut out the glass from the frame and reapply the primmer and then glue it together. I had one glass shatter due to a small nick that the saw made as he cut it out so be prepared for that.
He said the glues are much better then they were back in the 80s because of airbags. Some car were having glass blown out of the car when the airbags deployed. Lots of posts in the past with all the step and lists of primmer and glues required if you want to give it a try.
I am going to buy one of the tops, thanks for making the run!!!
Old 05-02-2012, 10:00 AM
  #184
ramius665
ramius665's Avatar
This is awesome. Can't wait.
Old 05-02-2012, 10:04 AM
  #185
J1720
J1720's Avatar
I'm in for one. Thanks for all the hard work!!!!
Old 05-02-2012, 10:09 AM
  #186
Own Goal
Team Owner
Own Goal's Avatar
Received 2,322 Likes on 1,395 Posts
Sort of late to the thread so pardon my laziness for not reading it all. Glass will be only available in Pilkington Optifloat Bronze and not a reflective #1 surface product like Pilkington Mirrorpane T.M. Grey? I've never seen one of these so would also like to know if 4-6mm tempered single or a laminated product? Either way, still interested.
Old 05-02-2012, 10:11 AM
  #187
PilkClassics
Originally Posted by jabriel
Can someone confirm if these would fit a UK '91 electric sunroof 944?
I'm def in for one if this is confirmed.
jebriel -- didn't forget about you. I asked my colleagues in the U.K. to look into this and haven't heard back yet. I'll call them again today to confirm.
Old 05-02-2012, 10:23 AM
  #188
PilkClassics
It is not Pilkington Optifloat Bronze. We only have Optifloat Bronze in 4mm or 6mm and this needs to be 5mm. This is PPG Solarcool reflective. It will be tempered, 5mm.
Old 05-02-2012, 10:34 AM
  #189
jabriel
jabriel's Avatar
Thanks - Fingers crossed. I'll probably want a spare seal in case its needed in the future.
Old 05-02-2012, 10:40 AM
  #190
PilkClassics
Let me know if this fixes the problem. I spoke with our Encapsulation Process Engineer yesterday regarding this. If there is a 1mm gap between the glass and frame, we can also run the whole rear hatch unit (glass and frame) through encapsulation and inject molding to the gap.
Keep in mind, just engineers talking here -- I have no idea what kind of costs are involved in this or how feasible it is. Also need someone adventurous enough to volunteer their rear hatch for an experiment!
Old 05-02-2012, 10:47 AM
  #191
Bri Bro
Bri Bro's Avatar
Looking at PPG material for some pictures, the only 5 mm I could find in Solorcool is the " SolarCool ® (1) Azuria™ Glass and it looks like it come in gray and bronze. Is this what is going to be used?
http://www.sterlinglass.com/SOLARCOOL.html
Old 05-02-2012, 10:52 AM
  #192
Bri Bro
Bri Bro's Avatar
It fixes the problem, I did three at the same time (one didn't make it) and they have been installed for years with no issues.
My glass guy said that he really didn't want to do any more...lots of work to cut out the glass. The gap is not continuous, it appears near the hinges. If you could find a better way to do this with less risk, I am sure you would get customers.
Old 05-02-2012, 10:54 AM
  #193
jabriel
jabriel's Avatar
Wonder if there will be a surge in the price of used (OEM) sunroof bags in June?
Old 05-02-2012, 11:05 AM
  #194
Dougs951
Dougs951's Avatar
Ha hope so, I have quite a few.
Old 05-02-2012, 12:51 PM
  #195
gregeast
gregeast's Avatar
Can someone please (pretty please, with sugar on top) measure the distance between the rear edge of the glass on their Saratoga top and the center of the hole that holds the rear latch in place?
I think I can convert the manual latches to work but need to know that distance...
Quick Reply: Pikington will make saratoga tops Again
