rebuilding engine, need some info/advise!!
Old 02-23-2012, 08:20 PM
  #31
TheDice951
TheDice951's Avatar
The MAF came with the car, the PO had no idea what was going on in life let alone the car. I had to learn what was installed by the ote PO's paperwork.... I got it at an awesome price...
Old 02-23-2012, 10:34 PM
  #32
carlege
carlege's Avatar
ok well looks like you're on your own. maybe you could find one used but most are sold with the kit.
Old 02-24-2012, 01:28 PM
  #33
TheDice951
TheDice951's Avatar
Just ordered M-tune!!! That will fix the issue?!? Lol
Old 02-29-2012, 09:49 PM
  #34
TheDice951
TheDice951's Avatar
Got my M-tune today, now I have to wait until I get my Computer back to start te fun!!
Old 02-29-2012, 10:45 PM
  #35
carlege
carlege's Avatar
you can start the fun without having the computer. Install all the parts and plug and play when you get your computer
Old 03-03-2012, 10:52 PM
  #36
TheDice951
TheDice951's Avatar
Yeah that's what I plan on doing. I havent started yet because im busy studying (promotion test). I was talking about the driving fun!!!
Old 04-07-2012, 12:30 PM
  #37
TheDice951
TheDice951's Avatar
FYI, replaced the older MAF kit with the M tune and still no change with running issues... I found this the weekend after!
I fixed the harness, replaced the knock sensor and it runs a lot better now. The way it was explained to me was if the knock sensor was bad it would pull timing. Making the car feel sluggish and backfire.
I will be getting a new harness, or making one, for this engine build. I have decided to do a modified stock build.. No more HIGH HP build for me.
Old 04-07-2012, 12:56 PM
  #38
Bri Bro
Bri Bro's Avatar
Good find!!
Is that the ground from the battery beside the sensor? If it is, it should be connected to the bell housing. You want to ground the engine block. Grounds on these cars are known to cause all types of issues.
https://rennlist.com/forums/9403870-post6.html
Old 04-08-2012, 06:08 PM
  #39
jss
jss's Avatar
side note.. what is o ring block? any pictures like to see more into this.
Old 04-09-2012, 12:02 AM
  #40
TheDice951
TheDice951's Avatar
Ignore the blown head gasket and merky coolant!! If you look on the cylinder between the blown part of the gasket you can see the ring machined out of the top of the cylinder. The part that is suppose to mate with the gasket. The helps hold the wide fire gasket in higher boost applications..
Quick Reply: rebuilding engine, need some info/advise!!
