Is it possible to run dual exp. tanks?
I´m thinking of doing steam vents for all four cylinders like corleone did on his 951.
is it possible to run them to a new smaller expansions tank instead of back to the original tank?
I think the original tank sits too low and the best location should instead be where the battery is located or what do you think?
Why are you going to run 4 steam vents? Are you having HG problems or something?
I suppose you could run them to a small tank somewhere, then run a 'master hose' back to the main tank. You still need to have that coolant cycling in the main system or the 2nd tank will fill up and overflow with nowhere else to run the incoming coolant.
