951 Clutch Replacement - Parts Costs
Hey All,
I'm about to replace the clutch in my 87 951, and here's the parts list and prices I'm considering investing in from 944online. Let me know if you think this is a good deal, and/or if there's anything else I should replace while I'm in there:
Cup Clutch Kit (clutch disc press plate, pilot bearing, release bearing&sleeve, rear main seal): $995
Rebuilt Flywheel: $169
Slave Cylinder: $109
Clutch Master Cylinder: $109
I was going to get an aluminum flywheel but the guy at 944online talked me out of it, stating that it only offers a marginal upgrade.
Suggestions/comments?
Thanks,
Jay
Thanks,
Jay
Cheapest i could find
Throwout was $225
930 disk cost $70
Clutch fork bearings Forget how much
Do your slave and master cylinders need replacement?
Do some research and see how much you can buy those parts individually. Cup disk seems very expensive for what you get
Throwout was $225
930 disk cost $70
You'll probably want a new (refurbished) clutch fork too, with shaft & bearings. Zims sells a rebuilt/reinforced/re-hardened fork for a reasonable price, you just have to return your re-usable core after you are done for a refund. That cup clutch kit sounds a little expensive too... Zims sells that same combo minus the pilot bearing for $765.
Just so proper terms are used, the pilot bearing is only $7 and goes in the end of the crankshaft.
Here's what I found:
Paragon - $202
Pelican - $186
Zims - $177
All for Turbo.
Where is this on their site? I couldn't find it.
Paragon - $202
Pelican - $186
Zims - $177
All for Turbo.
Don't forget new flywheel bolts, and pressure plate bolts, and the guide tube that goes inside the bell housing. Southbend turns around disks so fast by mail that they may very well beat your local resurfacing place.
I bought the kit Paragon offers, came with everything except the T/O bearing!
Throwout Bearing from KO Performance, w/ free shipping: $158
Best I've found... http://www.koperformance.com/part-nu...6-082-01/SACHS
