Koni
Koni
Hey guys
I need to know if these struts are rebuildable?
here the part # 8751-1136
I have a bad strut, and today I was looking under the car and it looks as if the struts I currently have aren't rebuildable, it says do not open so I would assume they are not to be, There although are two small holes on the upper portion, to use a tool.
Thank you in advance
jurg
951-87
jurg
951-87
You cannot install a new insert in them. However, there are people who can "rebuild" them. You can even have them re-valved if you want. Contact koni and they can tell you who can re-build them.
7th Gear
Jurg, you can either send the defective strut to Koni for rebuild or you can use Koni's new 8641-1414 insert that is made specifically for sealed struts. If you do go that route, I'd recommend replacing them in pairs.Paragon Products jason@paragon-products.com
