Who manufactures widefire Head gaskets?
I have read that it is recommeded that if you are going to run higher boost use a wide fire HG. I have one, but I also have head gasket problems. Are these gaskets really any better?
JohnK |
Manufactures? Dunno.
Sells? Try Huntely, Zims, Paragon..... Scott '86 951 |
They are considered required if you plan of running more than 1bar of boost. I have the packaging from one that might have the manuf. name on it. I'll reply later tonight.
If yours busted, you might be detonating, have uneven head or block surfaces, wrong torquing, etc. Dave |
Victor Reinz is the OEM for the gaskets.
If yours busted, you might be detonating, have uneven head or block surfaces, wrong torquing, etc. |
