Garrett TO4E/46
Old 03-10-2003, 05:57 AM
stv951
stv951's Avatar
Post Garrett TO4E/46
So I believe T04 is the size. What does E/46 mean ? Is it a hybrid turbo ?
Old 03-10-2003, 09:07 AM
jimbo1111
jimbo1111's Avatar
Post
T04 is a type of compressor housing sold by turbonetics and garrett. e/46 is the compressor trim, size of wheel. A hydrid turbo is a product you end up with when parts from different turbos are combined. Like turbonetics compressor housing with a garrett center section and a kkk hot side with a garrett cliped wheel. hope this helps yasou.
Old 03-10-2003, 09:23 PM
Luke
Luke's Avatar
Post
"our" hybrid turbos usually consist of a kkk center section though.
with a Garret center, you could run "big shaft" 's and in return, be able to run HUGE compressor wheels in a T4 series housing.
Like a T61 in a t4......... the T61 flows more than THREE times the amount of air that a k26 can !!!!
Old 03-10-2003, 09:44 PM
Danno
Danno's Avatar
Post
Yeah, hybrid can mean anything. You can start with a 90% KKK turbo such as the stock K26/6 and turn it into a 'cheater' by installing a larger Garrett compressor wheel (after machining compressor-housing to match).
Or you can go all the way to a 90% Garrett with ball-bearing center section, full-Garrett compressor & turbine wheels with only the KKK turbine housing retained to bolt up to the stock 951 downpipe and crossover.
Old 03-10-2003, 11:01 PM
jimbo1111
jimbo1111's Avatar
Post
My center section isn't a kkk it's a semi replica with a ball bearing machined in.
Old 03-10-2003, 11:15 PM
Russ Murphy
Russ Murphy's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">What does E/46 mean ? </font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">It means that, with a 2.5 liter, full boost will be realized at around 3500 rpm and your car will run like a scared rabbit from there to around 6000 rpm.
Old 03-10-2003, 11:19 PM
Luke
Luke's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by jimbo1111:
<strong>"our" hybrid turbos usually consist of a kkk center section though.
My center section isn't a kkk it's a semi replica with a ball bearing machined in.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">but it's not a garret. I think I've only seen one garret center section in my life that was watercooled. ( hack job? )
Some manufactures cast their own "replica" kkk center and hot side housings.
What is a 'semi' - replica.
By deffinition, wouldn't a replica already not be completely the real thing? <img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
Old 03-11-2003, 07:19 AM
Magown
Magown's Avatar
Post
Luke, when you say you've only seen 1 watercooled center section, are you meaning installed on a 951? Every Volvo Turbo from 1987 to 1990 came with a watercooled Garret T3.
Old 03-11-2003, 09:13 AM
jimbo1111
jimbo1111's Avatar
Post
A true replica would be mean patent infringement.
Old 03-11-2003, 04:25 PM
Luke
Luke's Avatar
Post
one example of a garret watercooled center section. Now it's two
interesting..... do they use a remote bosch pump?
Old 03-12-2003, 01:07 AM
nine-44
nine-44's Avatar
Post
<a href="http://www.egarrett.com" target="_blank">www.egarrett.com</a> You'll find plenty of watercooled Garretts here. Garrett is a marketing name of Airesearch, I think they have quite a few watercooled turbos as well. Most dating back to the 70s and 80s.
Old 03-12-2003, 01:09 AM
nine-44
nine-44's Avatar
Post
The Ford Thunderbird Turbo Coupe and SVO mustang used watercooled Garretts also. Along with the TDI VW, that turbo is on the site under OE GT-17.
Old 03-12-2003, 12:59 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Post
Garett has been making turbos since the 40-50's for planes
Old 03-12-2003, 01:02 PM
toddk911
toddk911's Avatar
Post
What type performance were these turbos in the Volvo's capable of and would it be worth calling junkyards to get a good condition turbo off one of these Volvo's?
Old 03-12-2003, 01:07 PM
M758
M758's Avatar
Post
Garrett is part of Honeywell.
Airesearch is the first name of the company started by Cliff Garrett back in the 40's or 50's
Previus name was AlliedSignal and now Honeywell.
FYI,
Honeywell makes therostats, Aerospace avionics, Jet Engines (turbos are really mini jet engines), and Consumer products such as Prestone and Fram.
The Garrett Turbo divsion is in in Torrance Californina.
Quick Reply: Garrett TO4E/46
