Metering Intercooler In/Out Air Temp
Does anyone know of an inexpensive way to meter intercooler In/Out air temp?
So far the only thing I've found is an Autometer gauge and temp sensor set up that runs around $250. (not worth it in my opinion.) I know there's got to be a less expensive way using some modified gauge and meter designed or another application. (i.e. like using a welding tank regulator control valve for a boost control regulator) Thanks in advance! |
Lindsey Racing has a system that will measure in/out intercooler temp ...and one other temp source...
www.lindseyracing.com hope it helps |
Ratdog... thanks for the info however that system is not less expensive than the Autometer system I mentioned (which in my opinion is nicer) and Andial...
http://www.andial.com/ Has the same system however I was unable to find a price... Thanks, I'll keep looking! |
http://www.autospeed.com/A_0807/page1.html
try the above link. This on an Australian website called autospeed. I have one of the meters but have not used it yet. It's a pretty good site. Tons of info relating to boosted cars. I bought a voltage meter from them for about $15 that is the size of a half stick of gum. Hooked it up to my o2 sensor for a slick unobtrusive air/fuel meter. |
Someone mentioned either here or on some other forum that Radio Shack has a meter tat worked well and wasn't too expensive. I'm going down there tomorrow to check this out since I've been wanting an intercooler temp-gauge for quite some time now.
Danno,
Keep us posted, I'd be interested to hear what you come up with. Thanks in advance! |
