venturi tube : why? and OK or not?
3rd Gear
What does the venturi tube underneath the intake manifold do? How do you know if it is OK or not; what to check for? I will have my manifold off in a few days to replace some bad hoses that have been bleeding off some of my "precious boost" so I want to replace anything else that could be questionable rather than go back later to do the same job over....right!
Thanx to all!
Frank, guards red 951
Thanx to all!
Hi Frank,
I was told the Venturi tube was designed to create vacuum for the brake booster when the turbo is creating boost. I am replacing hoses under my manifold right now. I ordered a hose kit from Powerhaus which eliminates the venturi. I'm not sure how well it will work because it seems that without it I won't have any brake vacuum under boost, but then again I should n't need brakes under boost, now should I?
-Robert
-Robert
