Help! I'm an electronic moron.
On the KLR plug connection so kindly provided to me by Danno, there is a pin(#6) labeled- U (sheet). What the heck is this?
It's a black &yellow 12 ga. that goes through the fire wall and becomes a red&blue 12 ga.
with four small red&blues coming from that transition. The four r/b's go to each injector.
Is this a 12v source? My batttery is disconnected and I can't reconnect it yet.
I'm so close to being done.
Looking at the wiring diagram for MY 88 951 it would appear that the blk/yellow wire is the ground or 12V connection for the injectors. The other wires to the injectors connect cylinders 3/4 and 1/2 to the DME at 2 different pins. Since my injectors and the wiring loom are about 10 miles apart from each other at the moment I cant actually measure which is which.
Wayne
Wayne
