Patrick's build thread. (IT RUNS!)
Old 02-21-2017, 12:00 AM
  #1246
Paulyy
Professional Hoon
Paulyy's Avatar
Originally Posted by 333pg333
Got a feeling that the block has been plugged anyway. The covers are superficial I believe.
Hope so. I'd keep an eye on it anyway.
Originally Posted by JET951
I see the new WTAC regs are out Patrick, No H pattern gearboxes allowed, too much of an advantage over those archaic sequentials.
Sean
HAHA.
Old 03-03-2017, 08:19 PM
  #1247
333pg333
333pg333's Avatar
So the new 2-1 (x2) headers are on the motor with double bungs for EGTs and Lambda. A ton of work has gone into them to make everything fit and also allow for max expansion. So far there's 7 slip joints on the system. Bit more work to go and then off to be coated. Much more time con$uming than I'd imagined. It's almost like running two 2 cylinder motors. Obviously quite a different motor to Shawn's latest build but promising numbers / curves for that give me hopes for this one.
Old 03-03-2017, 09:02 PM
  #1248
Jon951
Jon951's Avatar
Awesome build. Beautiful creative work!
Old 03-04-2017, 01:16 AM
  #1249
Paulyy
Professional Hoon
Paulyy's Avatar
Nice work!
Old 03-04-2017, 08:58 PM
  #1250
refresh951
refresh951's Avatar
Looking Good Patrick!
Old 03-04-2017, 11:19 PM
  #1251
333pg333
333pg333's Avatar
Thanks guys. Few more bits and pieces to do and then finish the exhaust. We bought a new radiator too for a bit of preventative maintenance so that's going in shortly. Then a bit more wiring to run the new ECU / Dash. Then just wait for the intake. We're in a queue for that. Probably still 4-6 weeks away on that as his multi axis router was down for 4 weeks waiting on parts itself.
Old 03-05-2017, 01:39 PM
  #1252
gruhsy
gruhsy's Avatar
Great photos! Thanks.
Old 03-05-2017, 04:10 PM
  #1253
ptuomov
ptuomov's Avatar
Looks very nice. The twin scroll will allow you to get enough separation between cylinders that the 180-degree exhaust interference is eliminated. That'll allow you a lot of freedom with cams.
What are the ports for in the primaries? EGT sensors, or high-sampling-rate pressure sensors?
The pipes have a quite a bit of surface area. Have you considered thermal barrier coating them? Purely functional, hiding all the beautiful stainless there...
Any thoughts on how well those slip fits will seal over time? Double slip? Also, will you have spring loaded locks on those?
Does the pipe size got up at the first Ys that combine 1&4 and 2&3? Have you given consideration to what sort of wave will that junction send back to the exhaust port? Just thinking out loud, I don't have any terrible well organized thoughts on that. Some people talk about "cross-tuning" in 4-2-1 headers and then some headers have steps to send back a reflected negative wave timed to the point when exhaust valve seat would otherwise go "sub-sonic". But as I said, just thinking out loud.
Old 03-05-2017, 05:38 PM
  #1254
ealoken
ealoken's Avatar
Superb job
Old 03-05-2017, 10:22 PM
  #1255
333pg333
333pg333's Avatar
Yes, the twin scroll is meant to offer a nice improvement in response / driveability.
Two sets of bungs per cylinder. One for EGTs and the other for Lambda sensors. Want to have as much control over the tune of this motor as possible.
All the pipes will be coated once they're finished. Yes a shame to hide the steel but we've never had an issue with the coaters we use. Definitely more efficient than uncoated.
Hard to say on the slip joints. There's a lot of them so hopefully they can work together to minimise individual movement. Some will have the lock tabs.
I think with the headers unless you have access to powerful CFD or are willing to make a number of versions and just do trial and error, it is just too expensive and labour intensive and we come down to the 'best guess' method. Interestingly when you see the turbine housing, both split sides are not identical looking. Not quite sure what effect this will have but assume Borg Warner has done a lot of R&D to come up with this arrangement.
Originally Posted by ealoken
Superb job
Thankyou. I just pay the bills.
Old 03-07-2017, 06:13 AM
  #1256
333pg333
333pg333's Avatar
Wastegates now tied in.
Old 03-07-2017, 07:54 AM
  #1257
ptuomov
ptuomov's Avatar
Did you consider expansion joint on that wastegate pipe? I think the wastegate pipe that sees variable flow is going to expand and contract most and out of synch with the rest of the system. Baybe the slip joints take care of it.
Old 03-07-2017, 11:19 AM
  #1258
V2Rocket
Rainman
V2Rocket's Avatar
patrick after all this (and surely you have a dry sump still?) why not tilt the engine upright?
Old 03-07-2017, 11:39 AM
  #1259
Paulyy
Professional Hoon
Paulyy's Avatar
Nice work again. I wish you had a single scroll already on this motor to see the difference.
Old 03-07-2017, 05:19 PM
  #1260
333pg333
333pg333's Avatar
I hope so too. There's a lot of slip joints through the whole system. Time will tell.
Just too many other things to consider and budget is flying out the door.
Lol...so do I in some ways. This whole idea of changing the turbo and going twin scroll has been a major exerci$e. Much more than I'd imagined. As Gustaf says, he made his decision on ROI and he might well be correct. I based much of my decision on Rod's experience with Twin Scroll turbos being very favourable.
Quick Reply: Patrick's build thread. (IT RUNS!)
