Patrick's build thread. (IT RUNS!)
#136
Did a little Google search on swirl pots so I can start to understand what the purpose/function of this setup is. I have lost fuel pressure on the track with my fuel level nearly empty - it would seem that most people with 944 track cars do not have something similar to this. Are you wanting to be able to get every last drop out of the tank so you can run longer races or carry less fuel or is this just for peace of mind on fuel supply?
#137
The swirl pot ensures there is always a supply of fuel at the main pump inlet. With higher lateral acceleration you can get some fuel starvation with the standard tank. I used to get a predictable engine stumble in some right hand corners before using a swirl pot with fuel running away from the pickup particularly toward the end of races with lower tank levels. Fuel cells have proper collectors and trap doors around the pickups to prevent those types of problems.
#138
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
#139
Professional Hoon
And the bad thing is ours is so close to the exhaust headers leaving no room for much custom work. i mean it's possible to make4-1 equal length headers but just it'll be a lot more screwing around.
#140
Rennlist Junkie Forever
If you're low enough that you have fuel starvation, you didn't put enough fuel in to begin with.
TonyG
#141
Haha. I coud never figure out how to put in more than a full tank... I would always get the problem in the last 10 minutes of 1 hour races regardless.
#142
In my real world I have never had any problem with my fuel cell. Suppose it depends on the design of your cell. I still have the swirl pot and pumps sitting in the garage if I ever need it..
Fill the tank up to the top so that it over flows... do 5 hard laps, come back in and fill it backup. Divide by 5. Now you know.
I always add enough for 3 extra full load laps to avoid fuel starvation.
If it's a timed race rather than a lap count race then I add enough to do 6 minutes of full load.
TonyG
#144
Well I'm essentially just following advice. With the car changes which will increase lateral loads a decent percentage (I hope) then this is a fuel starvation prevention issue rather than running out of fuel issue.
In regards to the amount of fuel pumps, the guy doing the wiring works on a lot of top end racecars down here and assumed that I'd be running 30psi regularly. One of the Evos he worked on with the last Superlap down here was running 30psi in the corners and 40psi on the straights. All running at least 3 pumps. I suggested that we won't be doing that sort of thing so I'm thinking 2 044s will be fine.
#145
Oh, ps...does anyone have pics of the 968 turbo RS intake? Was it different to the 951 version (apart from what I remember they might have been Magnesium?).
#147
Whew. Thought I was crazy for a minute there. No steering shaft. That's the difference.
#148
The downside of that is that if you want to buy aftermarket headers such as SFR...they don't fit.
#149
I was discussing the stock intake with the engineer and he wasn't so quick to dismiss it based on what the factory deemed fit for their program. He felt that making custom intakes could become a bit of a goosechase and wasn't that keen on ITBs for turbo cars.
#150
As far as I know the standard 951 intake was used on the factory 3.0T cars.
They seem to have made it all from the proven & cost effective side since they had a power-to-weight rule to comply with - using the 16V head may have made a killer car but that couldn't have competed.
