Intake manifolds
Done With Sidepatch
Try <a href="http://www.extrudehone.com/automotiveaftr.html" target="_blank">Extrude Hone </a>...They show a price of $585 for a Porsche 924/944 Intake...
Couldn't afford it myself but they're some on the list that feel it's an effective modification.
I would like to see flow-numbers for individual runners before & after the extrude-hone process. The runners themselves are mis-matched in stock trim and there would be a great benefit to balancing them in addition to increasing the overall flow. In fact, if the extrude-hone were to exaggerate the flow-differences, I would think that upgrade can actually be detrimental to performance (more risk of blowing up that one lean cylinder).
Do I hear an Amen?
Rennlist Junkie Forever
I've done the extrude intake manifold. Save your money.
Dyno results before and after on my old car (K27/6 with Powerhaus head) showed less than a 5HP increase.
The results with Extrude Hone vary from job to job. Further... the Extrude Hone process is a poor substitute for real port work (although cheaper).
The SFR manifold, or any other custom intake manifold, does something very different than Extrude Honing a stock manifold.
The stock manifold has long runners, which are tuned to make peak engine TQ at a certain rpm (low end/midrange). The short runner intake manifolds (like the Huntley, SFR, Lindsey, & Milledge) are tuned to make their TQ peaks someplace else (much higher in the rpm range.
These custom intakes are only of a real benefit if you change all of the intake/exhaust/cam/head/turbo components to aftermarket components that are ALSO designed to make their TQ peak higher up the rpm range as well.
