LS6 Project
#76
Rennlist Junkie Forever
Also... since the engine is out of the car, you should "pin" the crank since it's a track engine to eliminate potential problems with the harmonic damper. Google pinning the crank and you should find out how to easily do this.
TonyG
TonyG
#77
Looking at the bell housing... is that the clutch slave line that appears to be "tuned down"? (this might be an illusion due to the picture perspective)
If so, get it pointed up, and make sure you fill and bleed (as much as you can) the clutch slave before installation. Then run a line up from the extension line you have to the engine compartment and put a speed bleeder on the end so you can bleed it.
TonyG
TonyG
#79
The red Energy Suspension motor mounts will eventually fail with track use I would replace them with solid chevy units the excessive heat from track use turns them to mush and the engine will sink and eventually be resting on the cross member. Look at the mounts offered by TPC they are a impoved design see the attached picture of my uprights used with a soilid chevy mount. You can see the solid chevy mounts on the photo of the engine this would be the easiest fix since you already have the RH uprights.
Your progress looks great nice attention to detail!
But the RH mount has a stop on it which will only let it "mush" so far before it compresses the urethane into the stop.
What I've found is that it will initially compress so that the engine drops about 1/8"+ towards the cross member, then stops because of the stops on the tops of the mounts. This after you've run it hard for a couple of track sessions.
I just make sure that I have 1/4" of clearance to both the hard power steering lines and the oil pan ... to the cross member on assembly.
I take a Demel with a whip end and a cuting wheel to the cross member after the first track day to make sure that there still proper clearance of these items.
TonyG
#80
Fantastic pic Sir. This is EXACTLY what I was looking for. So much room to move just in that spot. Fantasic news. (Edited for rule humor)
#81
Just out of curiosity... why are you going to move your firewall? I realize it's to move the engine back... but that will potentially cause problems in most classes of racing (especially if you start winning). But what do you hope to achieve? And how, and how far, do you plan to push the transmission back?
TonyG
#82
Tony-that picture is several years old and you are correct I even milled the square boss off the block before I installed that engine and made a guide to protect the lines. I remember reading when you had a problem of the oil lines getting cut. I also don't use braided lines anymore I switched to the Mocal line and push on fittings much easier to make up easier to guide.
#83
Without the bosses, the lines can sink in the "V" created between the steering rack and the block pinching the lines closed partially (however, at least they won't get cut by the bosses on the block).
TonyG
#84
TonyG
TonyG
with the motor further back, 2 important things will happen. Hood clearance, and maintained suspension geometry. (no spacers needed) As a bonus of installing the motor in this obvious spot, is of course Polar moment of inertia will be greatly enhanced as the Mass of the motor will be moved mostly behind the center line of the front wheels.
The transmission will not move it's spot.
#85
Who said anything about MOVING the firewall? see edit. Honestly, I'd be surprise if anyone could pick anything different about my firewall when I'm done. And if they do, it will clearly be for safety purposes. Clutch Scatter shielding.
Once you go there, you're stuck in classes racing cars like 997 cup/RSR's, and full tube framed race cars, 800HP 911's, etc... where you'll get killed.
That's why I asked.
TonyG
#86
Tony.. stop..my safety and cage comments were sarcastic humor where the tone gets lost in black and white letters.
I will not be winning much of anything. I will be beating up the car and working out the bugs for quite a while. Enjoying track days and such. My actual races will be in Time attack first. AND if I feel like I have an urge to scrape up the car and create dings and cuts and possibly wrecks.. I will race in a NASA series. The car meets rules in so many directions. I made sure of it. If I want to swap in a 2.5 motor and go.. It will be a breeze. If someone wants to complain then, it wont be because there is a tiny pie shape cut out of the firewall. It will be because I drove faster than them. And did all the detail work they didn't like low friction bearings, full under tray, real, working aero, etc. etc. Most of them wont protest anyway. Like your area, we will know most of each other's little differences and be in agreement. I really like the Porsche club guys, and nothing will happen without their knowledge first. You should understand that more than most, a guy who drives a Porsche with a V8 in a Porsche motor only class. They all know, understand, and welcome the fun.
#87
I've seen so many cars taken apart as a result of a protest it's not funny. It's not a deal if you're not winning. But if you do... you better be prepared to have the car taken apart in little pieces and scrutinized to the x^10th degree.
Yeah... that little firewall alteration puts you into serious company.
TonyG
#88
I'm not running spacers! By chance, I just happened to have a large scoop mounted right where the LS throttle body sits I had to make a notch in the carbon fiber to make it work. I also painted the throttle body black for stealth reasons.
#89
I run the spacers and I never want to take them out. Seriously.
I also run the same size spacer on the transmission mount.
Yeah... drops the CG of the car.
If you have a geometry issue, redrill the cross member and get a 911 bump steer kit.
TonyG
