How many seals and belts on front of 951?
How many shaft seals are there on the front of the 951? How many belts? I know there is a timing belt, but presume there are balance shaft seals too? Finally, if you were going to change a timing belt and a leaking balance shaft seal, would you not change all the others too? Thanks.
Well, let's see...
1) Crankshaft seal... also needs O-ring to seal the oil pump drive gear.
2) Camshaft seal... also needs mylar gasket to seal the wiper. Also a large o-ring and a small gasket.
3) Balance Shaft seals (2) also, 2 mylar gaskets.
Belts:
Timing belt
Balance Shaft Belt
Alternator/AC belt
Power Steering Belt
Change them all at the same time... also, check all of the idler rollers and the water pump for replacement...
Belts:
Timing belt
Balance Shaft Belt
Alternator/AC belt
Power Steering Belt
