Bursch Test Pipe
guick question, i'm trying to buy a used test pipe from a guy with an '89 Turbo and my car is a stock '86 turbo. on pelican the bursch test pipe is only listed for 86-88. will it bolt up?
The later cars use a football shaped flange for the wastegate tie in. Your car should have a clamp instead. I used an '89 Bursh pipe on my car by cutting off the flange.... or I suppose you could just secure it out of the way and hope it doesn't rattle... Or you can use a later style wastegate tie-in flange on the wastegate side. So, yes, you can make it work, but you'll need to adapt a bit...
fabspeed sells the flange for $30 shipped.
or you can try to find someone who is parting their car or decided to do a WG dump.
Or cut the flange off on the exhaust side as Tom said.
