aluminum vacuum restrictor
hey guys, i fixed my low boost issue. i had just forgotten to hook the TPS plug back in.
i still have this small aluminum valve that has a hole drilled in it. it was in one of the large vacuum lines that run to the idle stabilizer valve i believe. it fell out so i'm not sure where it was originally.
since i did lindsey's venturi delete kit, is it important that i have that vacuum restrictor in there somewhere? what's it for?
