Engine Installation..
Is it possible to reinstall the engine through the bottom with the crossover pipe still attached? I have the car up about 23 inches from the bottom of the bumper to the ground, but I may just remove the rest of the strut to get it through the wheel well.
can you install the crossmember to the engine with it out of the car to get some stability and lift the front of the car up with a hoist and slide it under there?
I've already gotten the crossover/dp installed and it'd be really annoying to have to buy/make new gaskets.
