Flywheel info
Flywheel info
hey guys,
can i get the number of the teeth on the flywheel and the position of the timing mark(for the sensor) inrelation to TDC on #1?
Oh is there a mark on the second row of teeth and how many degrees out is the other mark?
Mike
Mike
For which car? On the 951, there's 132 teeth and 944NA, 130 teeth. The reference sensor is at 58.64 degrees before TDC.
Do you have your flywheel out of the car? Can you measure the angular position of the two front-most triggers on the flywheel in relation to the reference-sensor trigger? Also can you confirm that one of the flywheel's tooth lines up with TDC? And that the reference-sensor trigger is lined up right in the center of two teeth?
Thanks!
Thanks!
