Beautiful Milledge motor (pics)
Old 05-16-2011, 06:39 PM
DVC
DVC's Avatar
Originally Posted by pettybird
is that one of those $499 rebuild kits on eBay?
Only $29,500 off
What car is this going in?... DADDY WANT!!!!
It has spent 3 years in a pretty serious NASA GTS 951, but he wants to go to NASA SU (Super Unlimited) so needs more displacement.
Old 05-17-2011, 12:19 AM
333pg333
333pg333's Avatar
So is this going be increased in capacity or is he going a completely different motor?
Old 05-17-2011, 09:34 AM
DVC
DVC's Avatar
Patrick- please tell me about the goodies in your avatar.
So for Unlimited he needs a 4:1 power-to-weight to be competitive, and will need a reliable 600whp. He's investigating going big N/A but I'm trying to talk him out of it.
Old 05-17-2011, 09:04 PM
evil 944t
evil 944t's Avatar
Wink
Originally Posted by PorscheDoc
Very cool. Though....all that custom stuff, and still using a stock 25 year old fuel rail.....he needs to hook up with CEP.
notice there is no AOS? he knows where to go...
Duke, he uses the factory pump as 1 stage and then a 2 stage external oil pump. I just re did the oil system on one of his setups and went to full drysump(no factory pump). We gained 60fwhp at the same boost level.
Old 05-17-2011, 09:44 PM
George D
George D's Avatar
Really? 60whp from a drysump. Mind explaining the additional HP gains? Thanks.
Old 05-18-2011, 01:00 AM
TexasRider
Late Porkchops
TexasRider's Avatar
That is top shelf!
Old 05-18-2011, 02:31 AM
JET951
JET951's Avatar
Is that a typo Dave?, 60 Fwhp. i just did a quick calculation and the factory oil pump takes 4.667 hp to drive. it should remain constant througout the rev range as the oil pressure relief valve opens at apprx 7bar.
your not using that new 55 nitros shot by any chance?
Sean
Old 05-18-2011, 04:44 AM
Duke
Duke's Avatar
The power increase should come from less resistance in the crank case due to vacuum and no oil bath for the crank to whip through.
Old 05-18-2011, 05:36 AM
JET951
JET951's Avatar
Im not too sure about that Duke. I dont believe the crank sits below the oil level. sure on the street/ track some oil may whip up on the crank but this should not get you any HP on the Engine/vehicle Dyno as the engine is stationary. Any oil coming down from the top end/ balance shafts drains that would hit the crank would be the same whether its dry sump or not.. and i have my doubts that some crankcase vacuum is going to make 55hp.The vacuum may help reduce oil leaks
Sean
Old 05-18-2011, 05:59 AM
333pg333
333pg333's Avatar
Ha, that's kinda ironic Travis. So the guy is trying to use a V8 and you're saying don't do it? haha. With the results of your incoming motor perhaps you might re advise him.
Those are the new Fikses. Trying to squeeze 315's up front. Might be tight. In hindsight I wish I went with similar wide body as your avatar.
Old 05-18-2011, 07:07 AM
Thom
Thom's Avatar
Anyone with a spare sump can check how high the level of fluid gets with ~6.7L?
Old 05-18-2011, 07:11 AM
evil 944t
evil 944t's Avatar
Sean
Yup, 60fwhp was gained. This was on an engine dyno not a chassis dyno. No tuning was done, the motor was torn down, dry sump installed and re dynoed. He has now turned the boost down 2psi and runs the same HP.
Actually, I have seen similar gains on a few other motors but, they were hard to compare because minor cleaning up of the heads were done at the same time. I only really have 1 motor that was kind of a back to back run with no extra work done
Sean, 75?? I never use anything less than a 100shot
Old 05-18-2011, 09:55 AM
elargentino
elargentino's Avatar
I gained 38-40 RWHP using Evil's dry sump. That's wheel hp.
Milledge himself would have always been the one to suggest that on ANY race engine (944), you dry sump first.
And if I am not mistaken, Milledge now uses Evil's system - looks like his to me in those pictures, because Milledge used to retain the OEM pump (redundant), but Evil's system does not. The oil pump is emptied and used as a front cover only.
Old 05-18-2011, 11:09 AM
DLS
DLS's Avatar
What is the little tank with the 4 nipples on the fuelrail for?
is it for the venting of the head?
I want more pictures with all hoses attached
Old 05-18-2011, 11:15 AM
Duke
Duke's Avatar
Looks like a vacuum tank. With ITB's there isn't a plenum to equalize vacuum from each runner.
Quick Reply: Beautiful Milledge motor (pics)
