Gauge Installation
Gauge Installation
how do you hook up the air fuel ratio gauge?and where can i hook up the gauge lights so that when i turn on my headlights the gauges turn on as well.thanx in advance
i have 2 gauges,boost gauge and a/f ratio gauge.in adition to that my lotek gauge pod is coming in so ill need some help you people who have already done this.the autometer a/f gauge has 3 wires,red,black,and purple.no white.so if you guys can help me out id appreciate it alot.thanx
For the air/fuel gauge, the red wire is a power source, black is ground and purple goes to the O2 sensor. You can hook that up to the wire INSIDE the DME connector. I beleive Danno has a writeup on that on his website <a href="http://members.rennlist.com/951_racerx/" target="_blank">http://members.rennlist.com/951_racerx/</a>
under replace clock with ARM 1.
The lotek pod is really easy to install. Mine fir perfectly.
