Oil Pump
Oil Pump
On our 951, it seems like the oil pump is going out. We aren't running low on oil (we've checked it about 100 times,) but sometimes when I drive the car too hard, or at other un-explainable times, the pressure reads really low, I've even had the light come on once or twice. Is this the pump going out? <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" />
Like Russ said, check the sending unit. Or the pressure relief valve could be binding. The oil pumps are very rugged, so that is not a likely suspect in my mind. Have you checked the crank pulley bolt to be sure it is tight?
