Need some info from anyone with an Autothoruty MAF and AFPR
Special tool:
No offense intended from me resulting from our earlier discussion.
Now my question: Did you change the settions on the DME when going to 2.6 with the 55 lb/hour injectors?
Do you mean the timing settings? I didn't change them. I don't have Guru chips - I only have custom Autothority. Both of those fuel pressures are with cis guage at idle. - Jim.
[quote] It looks to me as if those are generic settings and not only for the guru chips but I may be wrong.
<hr></blockquote>
Those settings are for the Guru chips only. APE chips have their own settings, I posted the values in another topic on the list recently.
*eurospeed951* if you and the car are up in the DC area now, email me if you are interested in custom chips for your 2.8L APE MAF setup.
<hr></blockquote>
"Any idea about what I should have my fuel pressure at?"
Look at your dyno-chart. Find the leanest spot and adjust your fuel-pressure up or down so this leanest spot is around 12.5:1 (gives highest combustion pressure). Changing your fuel-pressure will adjust your entire fuel-curve up and down as a whole.
