Difficulty to install/replace downpipe?
Kieth,
If you consider an aftermarket muffler, which attaches to the cat-back pipe, then I would say yes. Or if you were considering the pipe that comes directly off the turbo, (turbo exhaust) again... you would be correct. However if you are doing as simple test pipe and exhaust, the Porsche factory set up essentially comes in two long pieces. From the turbo exhaust pipe back, it's only the cat pipe in one piece and the cat back and muffler in another piece.
In my humble opinion, it's not worth it to go with 3 inch pipe. Because YES then you WILL have to change that "down pipe" which pretty much is a BITCH! AND without an upgraded turbo, it's kinda pointless. Now you've just taken a $600 30 minuet testpipe and aftermarket exhaust job and turned it into a MAJOR $2500 turbo and exhaust change that is likely to take an entire weekend.
Which is likely to also require another $1500+ MAF to go with that turbo. Now where fast approaching $5000. While yes it is a significant upgrade that can get you 350+ hp, I dont' think that's what he was originally talkning about.
If you don't change the turbo, then you have to get a custom fitted down pipe that will work with the stock turbo (which is still a bitch to install) and if you DO upgrade the turbo later, you have to through that down pipe out and buy a whole new one.
A 3 inch pipe is too much BS for too little gain (over the stock 2.5 inch pipe) in my "humble" opinion.
