Just Ordered A-Tune
Old 05-03-2011, 10:37 AM
  #196
reno808
reno808's Avatar
wow thats nice. no cut and splicing i see
Old 05-03-2011, 11:41 AM
  #197
blown 944
blown 944's Avatar
Originally Posted by toddk911
Two questions I will post here in case anyone else was wondering in re to the MAP.
1. Is it or will it be possible to use your MAP for boost data logging/tie in to Zeitronix, etc. ?
2. With running the MAP, would it be possible to run a true BOV now?
Todd you can log the signal but tge scaling is slightly different iirc.
To the second question. The MAP sensor doesn't make a difference in the operation of an open BOV. The air has already been measured by the MAF therefore the fuel has been added. I don't think you can compensate fast enough to avoid a rich condition.
Old 05-03-2011, 11:59 AM
  #198
MG944
MG944's Avatar
So with having two tunes available is it an option to run e85 on one tune and 91 octane on the other? Meaning is there an e85 tune available for n tune? Also what is required to run e85? Software change only?
Old 05-03-2011, 12:11 PM
  #199
schip43
schip43's Avatar
Oh yeah! Vent to Atmosphere for me!
Screw that, I'm gonna bring on the Noise!
Old 05-03-2011, 12:20 PM
  #200
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
Trust me, not venting to atmosphere, it's PLENTY audible. You'll be fine.
Old 05-03-2011, 12:39 PM
  #201
Zeff
Zeff's Avatar
Get some sounds
Old 05-03-2011, 12:53 PM
  #202
m73m95
m73m95's Avatar
There isn't a need to run e85 in an NA car. Octane isn't an issue for us.
I did it so I could get a little experience tuning with e85, and to see if I could save any money at the pumps. I do save, but its only about $3-5 per tank. Nothing to get excited about.
If you wanted to run e85 in your NA, it is possible. Rogue advertises a way to switch between tunes, so you could run gas on one side, and e85 on the other. You *might* get away with only changing the FPR to a 3bar, for the extra fueling needs of e85, but larger injectors might be needed as well.... Rogue will have do the calculations to know for sure.
Old 05-03-2011, 12:56 PM
  #203
m73m95
m73m95's Avatar
More rice than a Chinese kitchen!!
Old 05-03-2011, 01:21 PM
  #204
blown 944
blown 944's Avatar
Yeah it's plenty loud. I was surprised it didn't quiet it down much. I ran it open for a long time then finally built a pipe to recirc and not much difference really
Old 05-03-2011, 01:23 PM
  #205
schip43
schip43's Avatar
Well if the map kit works well and you have the E85 setting, which should mean more aggressive
engine timing, that would be a game changer in the N/A world also.
That setting would work with water injection also; so head work, more compression and a more aggressive cam and you should be able to pull more power out of the N/A's on the base 2.5, I would think at the least 944S power levels?
Old 05-03-2011, 01:34 PM
  #206
schip43
schip43's Avatar
Yeah I knew that would be coming!
I wanna *** load of mods also! (I only got a butt load of mods)
Lots of EVO's and STI's out here and they all sound like appliances no soul. I wanna sound as crazy as the old school N/A crazy *** modded 911's back in the day!
My 951 is not a DD anymore so what the hell!
Old 05-03-2011, 02:43 PM
  #207
86 951 Driver
86 951 Driver's Avatar
Is there a release date yet????
Old 05-03-2011, 02:51 PM
  #208
reno808
reno808's Avatar
I am going to run one just because i know how much the 951 crowd hates them. I just gotta find the loudest one...
Old 05-03-2011, 03:23 PM
  #209
adwolfe12
adwolfe12's Avatar
My friend has a GTI and the same Forge DV that most 951 guys run. So what he does is mounts it backwards and then you have the dying chicken noise you all want.
Old 05-03-2011, 03:30 PM
  #210
adwolfe12
adwolfe12's Avatar
Being in NE you should have easy access to E85 right?
I think any 951 owner should run e85 if it is close by. Way cheaper than 93, especially now, and is about 105 octane and with the cooling effects some say up to 110. Win, win, win.
Plus Rogue can easily have you set up for e85 and 20+ psi all day long.
I would but currently I have the stock injectors and Rogue recommend's that the A Tune is best with the stock injectors and it doesn't include a E85 tune.
So if/when I upgrade to the M Tune I could run E85 because it is all over here I will run it.
But is there really any gain with the stock 26/6 on E85? Doesn't it pretty much die at 15-17psi?
Quick Reply: Just Ordered A-Tune
