Just Ordered A-Tune
Old 05-02-2011, 12:56 AM
  #166
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by adwolfe12
The A Tune makes 4th gear so much more enjoyable.
Thanks, Rogue
Glad you are enjoying the Tune!
Originally Posted by MG944
So I'll be the one to ask. Is n tune MAF w/ MAP or MAP only?
MAP only - Speed Density conversion for the NA guys
Originally Posted by rocketrider2
Josh can you provide me a little guidance. I have an 88 non S thats stock. The injectors were just taken off and cleaned/blueprinted. I want to go with the A tune and later upgrade to the M tune. For now what do I need to upgrade to your A-tune? This is what I have on my list:
2.5" test pipe, or should I upgrade to a full 3" from the DP back?
3 bar FPR
Tial 38 WG
Will the CV handle boost or do I NEED a boost contoller of some type? Thats the big question and the only thing holding me back from ordering the A tune right now.
Lane
Lane,
Your car is a prime candidate for the A-Tune! Not a problem if you are currently using the stock CV to control boost, the A-Tune will work with it.
Old 05-02-2011, 01:11 AM
  #167
racerxrick
racerxrick's Avatar
Thanks, Rogue
do you mind if I ask why your referenced 4th gear specifically?
Have fun!!!
Old 05-02-2011, 01:39 AM
  #168
MG944
MG944's Avatar
So what kind of results are you getting with the map? Is there a temp sensor? Most importantly why map compared to maf; why map only?
Old 05-02-2011, 02:05 AM
  #169
schip43
schip43's Avatar
Have fun!!!
He can answer for himself but I can answer also.
My Max chipped (and supporting mods ) is a monster on boost!, but unless your doing 120mph, dropping it into 4th at anything below 70mph basically shuts down the motor!
Autobahn gearing and a 60 mph speed limit give me basically two overdrive gears
so improved drive ability sounds real exciting to me!
Old 05-02-2011, 05:28 AM
  #170
bimmen325
bimmen325's Avatar
this sound like what i need, i just do not want to mess with a pb, the maf conversions leave much to be desired, i could bearly get everything to fit and the airfilter had to get a crush to fit. Car buckles on take off and it is nothing as smooth as the afm.
Old 05-02-2011, 10:35 AM
  #171
schip43
schip43's Avatar
Yeah I got a Huntly Racing/Racing ARC ONE (is it) Maf Kit with my 951, PO (my best friend) had to fight to keep me from installing it! Never did , he kept mubbling about not enough air flow(it was for an S2) and having to tweak sittings when cold etc.
So far the guys that have Rouges kit seem to be very happy with their results!
Old 05-02-2011, 11:42 AM
  #172
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
with the MAP, the car is able to adjust the fuel and timing based on boost, not just on throttle position or the AFM. Porsche built a Temp sensor into the AFM. MAP + MAF = M-tune, which is flat incredible.
MAP only = A-tune which I don't know much about, other than it's similar to what many N/A cars are running today.
Old 05-02-2011, 12:35 PM
  #173
86 951 Driver
86 951 Driver's Avatar
Lane,
Does your chip allow a person to run more boost with A-Tune and the stock CV? I do have a lindsey boost enhancer not sure if that would be good to use with A Tune or not.
Old 05-02-2011, 12:51 PM
  #174
carlege
carlege's Avatar
"3Bar MAP sensor addition. Now the DME knows and understands boost pressure! "
Just read his site
Old 05-02-2011, 01:16 PM
  #175
schip43
schip43's Avatar
I'd lose the Boost enhancer if you go with any kit!
Old 05-02-2011, 02:35 PM
  #176
mtnman82
mtnman82's Avatar
pm and email sent Joshua. Looking forward to hearing back from you.
Old 05-02-2011, 04:48 PM
  #177
MG944
MG944's Avatar
"So what kind of results are you getting with the map? Is there a temp sensor? Most importantly why map compared to maf; why map only?"
To clarify I'm asking about n tune for the na cars.
Old 05-02-2011, 04:58 PM
  #178
Scott H
Scott H's Avatar
Simply put, it isn't needed. As rogue said it's going to be a speed density setup and all that needs is a MAP and TPS sensor to correlate load to how much fuel to inject. You won't need the barn-door AFM anymore, which should give you a few horses since you no longer have that restriction.
Old 05-02-2011, 06:46 PM
  #179
schip43
schip43's Avatar
Uh Oh, he said the "R" word! And I'm gonna go there! OK now I think (even though I don't have his gear) Rogue's gear is the best think that has happened to our cars since the invention of the "wheel" Specifically great performance and features at what would appear to be a great price! I have E85 around here (well more or less,so I'm gonna be all in)
But, I think the main reason to ditch the AFM, is because it's just one more old moving part to get rid of. So in essence enhanced reliability. My car runs a AFM at the moment and I have had no issues with it, other than the fact that anytime I want to do something to the motor the AFM always seem to be in the way!
Just saying no need to go overboard!
My understanding is that the AFM will support up to 400 hp?
Old 05-02-2011, 07:49 PM
  #180
adwolfe12
adwolfe12's Avatar
Yep you pretty much got it right. Even when just driving the normal 45-55mph range around town I would have to downshift to 3rd to keep the car form bogging when coming to a hill.
Now I can make it up a hill in 4th with just a little throttle input.
Also when you need to GO 4th pulls pretty hard!
Quick Reply: Just Ordered A-Tune
