FIXED!!-- no power in boost and sounds funny --FIXED!!!!
Yeah it sounds like a boost leak to me also. I had problems with the TB to hard pipe coupler, it looked ok but it would pop off under boost, at 4000 rpm and it sounded like a water fall. I'd replace that one at the minimum and see if that helps
Although I agree with the majority with a possible boost leak, the rough idling seems like a different problem. I would maybe check the TPS next. Possibly ISV also.
What year is the car? If '86, do you have a venturi delete?
its not a boost leak, i have check, multiple times and replaced couplers and boost pipes as well.
it is an 86 and yes it has the delete
no cat, all exhaust is piping is good and the muffler is a straight through so its not blocked...
i will be doing the TPS check tomorrow
the diverter valve is a forge unit and seems to be working properly. i will be checking the TPS today and screwing with some other stuff too... we will see what the results are.
thank you guys for helping me figure this out... its getting frustrating....
Ok so I checked:
Pre turbo exhaust
Turbo
Boost pipes
The turbo spools fine, boosts to 12 lbs as long as I get into it slow. If I press the gas too fast it stops accelerating and starts popping.
Please I need some other ideas!!
Pre turbo exhaust
Turbo
Boost pipes
- When you press the accelerator too fast, where is the "popping" coming from? Exhaust/ Intake?
- Which injectors are you using?
Yes, if it sounds funny it has to be something that changes the sound. A collapsed up pipe makes a lot of sense and fits the problem profile but supposedly this has been checked? Maybe the collapse was not noted in the inspection.
I pulled the entire exhaust off and checked what I could... I was checking for cracks and signs of leaks. I didn't notice any collapsed tubes...
The popping sounds like it's coming from the exhaust....?
