Best way to 300 rwhp
Old 12-10-2001, 07:33 PM
  #46
Ski
Ski's Avatar
Post
Ok,,,do you have it hooked up? How is the idle? How is it driving and did the harness match up?
Do you have an A/F gauge,,I'd be curious how the mixture is now.
Ski is offline
Old 12-10-2001, 09:18 PM
  #47
Luke
Super User
Luke's Avatar
Post
The intake man. fuel rail intercooler pipes and half the turbo are disconnected as i am changing the oil pan gasket as well as the turbo. Sorry.
I have alot of confidence in MP though.
Luke is offline
Old 12-10-2001, 09:23 PM
  #48
Luke
Super User
Luke's Avatar
Post
I do not have an A/F meter at the time. I have instruction on how to do it by ear but ill prolly pick up a gauge.
Its winter and i am in no hurry. Sorry man. I have to many small things to attend to in the mean time. My goal is to have the car ready for spring break so i can take a trip to Gingerman while all my buddies are in Cancuun.
Luke is offline
Old 12-11-2001, 03:30 AM
  #49
Danno
Super User
Danno's Avatar
Post
Aside from fueling issues, one of the main reasons to go with aftermarket chips is to remove the stock overboost protection at 13psi. Even if you keep the boost at stock levels, the increased flow will cause your computer to meter inadequate fuel. That's because under full-throttle above 3500rpm, the computer ignores the air-flow signal and uses a simple look-up table of injector-duty cycle vs. RPM.
If you upgrade the turbo, you'll definitely need K27 or custom chips. Even the AA Stg.2 chips won't work because they're mapped for the dropping boost-curve of the stock turbo while your replacement turbo most likely can hold max-boost to redline.
Danno is offline
Old 12-11-2001, 02:41 PM
  #50
Luke
Super User
Luke's Avatar
Post
yep that s pretty much what i said bout' the k27 chips.
13lbs though???. I was making 17 before my KLR started responding. What are the part numbers on the stock 951 FPR 's ?????
I think i have a 3 bar.
Luke is offline
Old 12-11-2001, 06:05 PM
  #51
Luke
Super User
Luke's Avatar
Post
Danno,
I think most people (autoxer's at least) buy the chips to "UP" their redline and stay in second gear longer.
Luke is offline
Old 12-12-2001, 12:48 AM
  #52
lou951
User
lou951's Avatar
Post
What is Jon Milledge's website address.
lou951 is offline
Old 12-12-2001, 11:59 AM
  #53
DanD
DanD's Avatar
Post
http://www.jmengines.com/
Check out that intake manifold!
John Milledge web site
DanD is offline
Old 12-12-2001, 10:18 PM
  #54
Luke
Super User
Luke's Avatar
Post
yep. too bad the carbon fibre intake is $4,800. Mr. milledge says it will add 30 horse to a motor that make 400!!
Luke is offline
Old 12-13-2001, 02:20 AM
  #55
rage2
User
rage2's Avatar
Post
That is one sweet looking intake. $4800? That'll take a LOT of work to convince the wife not to kill me...
rage2 is offline
Old 12-13-2001, 08:38 AM
  #56
Danno
Super User
Danno's Avatar
Post
Hey are those 4 separate throttle bodies I see there? Are they mechanically linked like the old carb setups? Or are they individually controlled by electronic motors like the BMW system? I want one!
Danno is offline
Old 12-13-2001, 11:19 AM
  #57
TurboGuy
User
Post
Rage2 did your 72# injectors work out ok ? Do you have a air/fuel meter if so what does it say under max load ?
TurboGuy is offline
Old 12-13-2001, 01:03 PM
  #58
rage2
User
rage2's Avatar
Post
I have the 72# injectors on my desk right now, hope to have them installed this weekend. Stay tuned!
rage2 is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
