What is the best intercooler up-grade?
Rainman
Its kinda funny now....that its fixed... but those pics aren't funny.
Can't believe it wasn't totaled (was it?). A co-worker backed into my passenger fender and dented it, and State Farm almost totaled my car . Apparently $1600 is what State Farm thinks my car is worth...
Rainman
How often are you getting hit and how important is it to you that you are able to drive your car home after an accident? I just don't see how that should be a primary consideration when buying a part such as this?
Please get agreed value insurance on your car... it is worth the investment and for as much as most of us drive our cars, its not really an issue (usually they limit yearly mileage and usage). It's well worth the peace of mind.
the thing is, your insurance inspector guy might raise an eyebrow if he sees that your bumper has notches cut out of it for your IC pipes to go through...that could change the agreed value that you get paid out for your car, they will look for anything suspect to not have to pay you. and if he does, then youre out about 1k for the intercooler plus who knows what your repair costs will be due to 'safety modifications'
If you have a track car, or a weekend car, that you want maximum power out of, then by all means, get the FMIC.
For me, my car is not only my DD, it is my only car. If it costs me 5hp to be a bit more road worthy, then that is a sacrifice I am completely willing to make. If I should happen to get hit (Or I hit someone), I need my car back up and running ASAP....insurance or not.
For the OP, it all depends on what you want from your car. This is my reasoning for not getting the FMIC. If you want the peak of what is possible with the 951, then by all means get it. Las Vegas drivers are absolutely insane, so I like having a little safety factor built in, even if it costs me a few HP. Maybe I get hit sometime, and maybe I don't. Its the same thing as having insurance. Its there if you need it...or in this case, its not there, in case I need it.
That's kind of my point.
Back to the OP... what mods do you have so far? I wouldn't consider an intercooler to be low hanging fruit on the "hp/$$$ based upgrade tree"... most don't consider an upgrade until 350 whp and beyond, as its not a huge bottleneck, the stock IC is quite capable.
I went nowhere near the hassle Jon/Techno Duck went through when I installed the SFR front mount IC, as I asked Tim at SFR to supply me with 2.25" piping instead of 2.5".
Though I got no clearance issue with 2.25" piping I realised how much of a pig of a job it would be to use 2.5" piping, as things look quite tight.
The install took me a couple of hours, and apart from trimming the bumper and the stock IC brackets it didn't require any "nasty" modifying of the shell or the cross brace.
I will install an IAT sensor soon so I should be able to measure how effective this IC is, at least put it in perspective with my engine set up.
The only annoying detail with the install is that one of the coupler supplied, the one between the IC exit pipe to the throttle body IC pipe is too short, I had the same problem as Jon.
Well we have always assumed you Americans park by braile so perhaps this is an area of concern?
hehe no really, someone should sell a bumper to go with the front mounts that is already compliant with the i/c. Wouldn't be expensive to produce and it would probably cut down on installation time and just be a nicer fit. My front bumper had to be ground away also.
definitely crashing is not something you plan to do but it does help to plan for it.
In my case, all 3 of the above apply to all my vehicles, as not only do I take care of the cars, but my kids ride in them.. I pay more a year in insurance premiums than some peoples cars are worth, but I happily do so. I recently had a 10MPH accident resulting in the total loss of my Audi, this resulted in a payout to me of almost double the book value of the car because of the coverage... and the accident was MY fault.. In my case, the cost of the pollicy covered itself, and then some!
Jons install was NOT typical, as he pointed out in his own thread he didn't install it as it was intended to be installed. HIS modifications are not required to install the FMIC as it is intended to be installed, and has been installed by many folks here... Simmilarly, MY install is not, will not be, and was never intended to be for everyone.. it is for me.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Back to the original question…
Even though I like modifying engines as much (probably more) than the next guy – the benefits of any intercooler upgrade on for a street car are pretty questionable unless you live close to the autobahn. The stock intercooler does a pretty good job and any decently modified street car won’t run full boost for more than 10-15 seconds at a time (my street 951 does 0-100 in 10 seconds).
Track cars are a completely different situation….and pretty much by definition a turbo cab is not going to be a track car!
BTW – my 968 cab with a 3l 16v turbo will be running a stock 951 intercooler. Easier to mount and its best to spend your money on things that make a difference.
BTW part 2 – I would like to recommend to anyone running a modified 951 that cell phone and AAA is a good idea. Even I use that combo on occasion (no spare tire – it won’t fit over big reds.). You can ask for a roll back and you get 100 miles of towing with the gold level. You can use it to transport your car anytime you want – if you wanted to get a roll back to have your car shipped to the shop from your driveway you can do that – even if there is nothing wrong with your car! Note – my 951 has never been towed – but I won’t’ fool myself thinking that it can’t happen – my Mini did get flat bedded home after the Alternator / supercharger belt broke. The electric power steering pump will kill the battery in 10 miles!
I have the roadside assistance on my auto policys... 0 deductable, and will even send gas if you run out, I have used this 3 times, 1 when my rubber clutch detonated in my 944, one when my Audi ( broken gas gauge) ran out of gas, and one when my Durango battery gave up teh ghost in a shopping center parking lot.. a phone call is all it takes...
In my case I would say that the SFR front mount intercooler has had a slight impact on how the car drives.
I noticed right away a slightly heavier nose/steering after the install. I do not think the SFR set up actually weighs more than the stock set up, but the core is located further away from the front axle and sits lower than the stock IC.
The difference is not significant though - as soon as the second drive I had forgotten how the car drove with the stock intercooler.
Have anyone measured or experienced any benefits using a big FMIC? The stock IC has a very good ducting and will be highly effective on a track or driving at high speed. So the question is how much is there to gain even on a track car. Assuming that the stock IC intake restriction is removed.
