Pauly's go quicker project. (Data Logs!)
Professional Hoon
Probably 18 psi will be my limit with the guru chips. Oz951 used these chips with a To4e at 18 psi and saw some great numbers. Right now i've even set the FQS switch for 65lb injectors since i'm using the stock 2.5bar FPR (same what oz did) and i've selected -2 ignition retard 18psi to be on the safer side.
Should be interesting results.
Professional Hoon
$500??? woah that's cheap. in aus they're around $600-$700 but i managed to find someone who can pick them up for $550.
performance parts prices down here are ridiculous!
Professional Hoon
eBoost2 Is installed. I used double sided tape (3M) to stick it on the side of the centre console and the bottom of the dash. If it dosn't fall down i'll let it stay there, if it falls ill probably make a pod for it to sit in, in the same location.
Professional Hoon
My leg just clears it. It dosn't fit under the headunit because its a 60mm gauge not a 52mm. And the law in melbourne and other parts in australia, we cannot have gauges higher then the highest part of your dash so no a pillar pods. Plus I'm trying to keep the stock look, as much as possible.
When i look down i can see it. There's no need for me to keep my eye on it while i drive.
Professional Hoon
Well it has 6 boost settings so it's possible. but if you're talking about when shifting through gears, it will chance boost setting by it's self, then no.
But what you can do is run 2 switches (most likley push ones) so when you cpress one your presets go up 2,3,4. and if you press the other one your presets go down 4,3,2,1. you can set it up for 1 button so each push will take it up 1 boost group and the other button will take it straight back to boost group 1. and there's other ways. There's RPM based boost also which i havn't read much about yet.
What i might do is move all the centre consol switched to the left and have a swith you can flick up or down to chance boost groups.
Professional Hoon
So i finished setting up my eBoost2. Here's a short video showing it working with an external switch to switch though boost groups.
http://www.youtube.com/watch?v=CRKHS8dKcAA
Professional Hoon
Started on the exhaust this weekend. we decided to make it all 1 piece at first to make it all right, then weld in the V-Bands. hopfully we start the front section on the exhaust this week.
