like to hear ur thoughts on manual steering rack swap
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Switching to a manual rack for ‘feel’ was popular on older cars with way too much power steering boost – it did give better feel. Switching to a manual rack on a 944 does not increase ‘feel’ – it will increase the ‘feel’ of hitting the curbs on the track and it will decease steering input speed, especially at the end of a long track weekend!
Don’t do it….no benefit other than a slight weight loss.
If the OP is only going to be driving maybe once a week it probably isn't going to be on the track/autocross course. If you do it yourself just keep all of the parts for the power steering you take off. Then if you don't like it switch back and sell the manual rack. Your rack is already leaking so you need to bench it anyway to replace seals and o-rings.
thats a good point. I think I will remove the belt for now to get a feel of what its like. I just love removing things from old cars and keeping engine bay as simple as I can. but will see I guess
FWIW, you can buy a rebuilt lifetime rack from autozone for under $200.00. A pump rebuild kit is about $20.00. Rubber feed line to the pump is about $40.00. All other lines that can leak can easily be replaced with bulk hose and hose clamps. For under $300, you can have a leak free system. You will spend more than that to get the manual rack setup in.
I want a power rack with a quicker ratio. Turn 3 at my local track, as well as most autocross courses, often requires me to turn the wheel more than 180' deg. (Which is ridiculous for a sports car)
By contrast, I run the same course with my friend's '98 328i and I never have to go beyond 120 deg to make the same corners.
Put a manual rack on my race car, but sometimes track another 951 that still has PS. Both cars are set up the same except for the steering rack. I really do not notice much difference once on the track. I changed to manual because I got tired of blowing the seals on the PS rack. Hoses too. Having said that, I would not want a manual rack on a street car.
ive driven street manual vs. power back to back and though the manual is ok, not real noticable 90% of the time, the 10% you do notice it kills it for me. Ive had my share of ps leaks to fix, but its just part of owning these cars. If i removed everything that leaks on this car i would be left with a set of seats.
Yeah, if you take out all the parts that could leak fluid, and take out all the parts that can leak in the rain, you aren't left with much.
Freedom Enthusiast
Remove hoses and drain... and belt of course. THEN you will have an idea.
When my car weighed 2500... de-powering the power steering rack was zero issue. Very little extra effort at low speed, and none at high.. Take a look at this video. It is with a de-powered , power steering rack.. I love the quicker steering. I truly needed even quicker steering honestly, I was having to turn the wheel too many circles to take the tight corners. a 16:1 is desired for AutoX. But, I will be on the road course mostly, so no need to decrease the ratio from here. watch me steer.. EASY to turn in tight corners. (except the having to turn too many circles) I was running 265 Khumos in the front. Maybe no ones leaving a reservoir for the fluid to transition when they de-power their racks?
I had my friend call out the cones bcuz I was going to wrong side of a cone and i didn't know where.. he took it upon himself to expand on the help! lol.. he's a good friend. If you look at my start, I only have to use my fingers to turn.. I had to turn my boost down to 10psi to keep from spinning the tires everywhere... So funny that lower power was better.
http://www.youtube.com/watch?v=FfHwSbndDBE
I have run both ways and totally agree that power steering has a much better feel on the track. I think I have very fast hands and still the manual rack limits feel and wheel response . Almost like the car gets numb (best way I can describe)
A few things to note: I'm running a manual rack because I have to per class rules; I run 245 tires up front; I have the minimum amount of caster that I can adjust.
If your "reason" for removing the power steering is to have a "cleaner" engine compartment, then I suggest you get rid of the 944 and buy 1960s pickup truck. I had a '69 Chevy, and it had the emptiest engine compartment I've ever seen. I would climb in and sit on the wheel well to change spark plugs.
