LS1 kit suppliers, list of avaibale suppliers
#76
The bellhousing/clutch adapter from RH is a nice usefull part as well as the oil pan. Very good quality on those parts. I dont want to turn this into a forum bash however I do want to let people know what to expect so they don't have deal with the same issues I have. If anyone wants to know the issues with the other parts just PM me, RH your welcome to ask as well. I'll respond privately.
The next conversion, if I buy from RH it will be just the bellhousing and oil pan. The rest of the parts could not be used and had to be custom made or sourced elsewhere.
#77
#78
Over 30K hard-core daily-driven miles on my 5.3l truck engine swap that Renegade said couldn't happen.Before starting the swap 3 years ago, I read many instances of fragged pilot bearings on their forum and decided to design my own Clutch/TT adapter. Since then, I don't know how many C5 adapter plates I've sold to individuals with burnt/friction welded TT shafts and pilot bearings that had a Renegade Kit installed. There is yet another pilot bearing discussion going on at the moment on 944hybrids. The Corvette C5 BHellhousing... GM (Not a Renegade design) part #12554980 is not the issue either with the shaft centering as I've dial-indicated 5 or 6 of them personally. The issue is the adapter plate and it's shaft locating/concentric dimensions along with the 3 locating dowels. Poor design IMO. Also the NA radiator and factory fans work perfect on the 5.3L as well. The 951 radiator has always been reported as working extremely well on the bigger displacement ls1/ls3/ls6 engines. Don't let anyone tell you any different. And the hood clearance issue has been remedied as well with a modified crossmember and new designed Engine mounts. The 3-prong rubber mounts are old-hat design as well....
#79
So you are saying everything is junk except for the oil pan and adapter plates.. and then we have documented instances of leaky oil pans and misaligned adapter plates. Yeah, sounds like a ringing endorsement for their products. I'll bet its fun having to pull the oil pan because the mfr never checked it for leaks... wonder if they reimbursed Anders for the labor on that one?
#80
I just installed Eric's pan on my L33 5.3L and it seemed to fit pretty nicely.
#81
The leak I had, was impossible to find with a visual inspection, and as Im guessings its a robot/jig weld, its probably perfekt 99% of the times.
As for labour, it only took 1-2 hours to change it, the "mental" aspect of it was by far the worst.
Broom, everyone loves pics, lets all agree that the most important part, is getting a proper v8 in!
A guy here with a 997 CUP, is putting a LS in it for the 2012 racing season here, thats pretty damn cool.
#82
it could have of course been found mounting an an fitting, and a pressure testing jig .
#83
No need to stir up the hornets nest, but hell, why not. I have formed a number of friendships on this site and there is not need to get nasty. I am welcome to provide any information requested on my V8 endeavor.
1. The kits can work as intended. It all depends on what each individual is willing to settle for. Changing the geometry of the engine chassis relationship and the brake push rod angle have consequences. I will no longer discuss quality of parts.
2. Championship fast in ST2 equals 1:32's @ Mid Ohio. That's 8.7:1 ratio. A well setup 951 with a V8 should be able to run in that area. We will see if we can produce the real deal - a potential National Championship car running at the sharp end of the stick. That is our goal.
3. I am a little ****, to say the least about my race car expectations. My conversion, that Eniac mentioned, is beyond what most would expect on this forum. Engineering was completed by a name race car builder with more than one Lemans win and a Trans Am Championship. Any parts comments in the past were from them.
4. And by the way, my car is not done yet but I am driving Road Atlanta this weekend in our newly purchased, Turner Motorsports M3 E36 (designated endurance car).
God Speed guys and good luck. I will report when my 951CTSV gets on track. Hell, I will report on the M3 too.
#86
#87
