Any advice for removing stripped flywheel bolts?
I got 6 of the 9 out and they were super tight because someone used red loctite. Three stripped. I tried vice grips and heating and banging with no luck. I test drilled a spare bolt and they seem too hard to drill unless there is a special bit I need. Any advice?
Dom
Dom
Drilling is quick, free, and virtually foolproof for those bolt. Welding a nut is probably a close second, but I always worry about zapping the DME if you don't unplug it. Whatever you do, don't use an EZ-out or any of those cork-screw type extractors. They will snap off and compound your problem exponentially.
Remove all the holds you can. Then drill off just the heads of the stripped bolts. Remove the flywheel and you should be able to remove the threads by hand or at most with vise grips.
Rocket Scientist
The extractors that Van linked you to work great. Like Brian said, you can get them at Sears. They'll save you time from drilling. Either way, you have options.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Be really careful with the extractor – you break it off (common occurrence) and you will be very unhappy.
If you really want the best way use heat and then a reverse twist drill bit.
Dom, if you are talking about the internal ones (aka "Easy Out"), then don't do it. Chris is right, they WILL break. Good news is if you have to drill the head off of the bolt, when you remove the flexplate, the remainder of the bolt is usually only finger tight.
