The LS1 swap has begun
#152
Especially in LA. And if you've heard of the term "CARB," it stands for "California Air Resources Board," which is the catalyst for all emissions standards that come into play.
An example here is that we've had catalytic converters here since 1973. They are newer to Europe. Because fuel economy is more important in Europe, you used to run lean burn strategies over there to improve mileage (by running A/F ratios around 17:1, going off of memory). That drives up EGT's to a point where the catalytic converters get cooked, so we could never do that (not to mention it would also increase NOX to the point where we couldn't pass our emissions requirements).
#157
Yep, I tow a small trailer to the track with it. Holds my race wheels/tires, has a tool box and gas cans.
At some point I'd like to get a truck/trailer and I'll do a full cage in the 944, but right now that's just not possible...
#158
Rennlist Junkie Forever
#160
That depends on how you define "emissions." The US has historially had MUCH more stringent emissions requirements than the rest of the world, where emissions are NOX and unburned HC. Compared to industrialized Europe, a lot of the US is lower in lattitude, where it gets more humid, etc. Plus with more and bigger cars on the road (which is really a fallout of our geographic isolation in WWII), we used to have BIG problems with smog.
I am awere of US emissions systems, i have "hor rod" background, so have ownd US made vechiles and my friends as well. early 70's emissions were more non catalytic systems, which air pumps etc. Remember well my friends 454 powered Chevy which only had about 200 hp because all emissions systems.
At least in EU countries emissions requiments are as tight as in USA, If i remember correctly, state of California have had quite stict regulations.New EU-5 standard is even stricker. What comes to economy-driven countries, EU countries joinded to Kioto-envirnonment agreement. For example USA, China & Russia did not. These countries said it would cost too much for their economy system. I know all of us who live in industrial countries must take these issues seriously. One of the main problem is, less we pollute, then undveloped high populationa countries pollute more and more, like India,China etc. So situation remains more or less the same.
Back to the cars;
yes we have some Ford Taurus here, unfortunately most of them are 6-cylinder cars.
Diesels in Europe does not produce that soot because new particel filter(good for EU-5 standard). We can though improve systems
#161
I do recognize that newer European standards are much more stringent than in the past. But between our safety requirements, which add size and mass to cars, and our preference for cleaner emissions over fuel economy, we are going to continue to use more fuel.
To give an example of how much our emissions requirements hurt fuel, take a look at what some recent diesel truck owners are doing. I've got a CUmmins 6.7, which has all of hte crap on there. Removing the EGR, DPF, and downstream cat typicallly increases fuel economy by about 30% (!). 15 MPG city becomes 19. 18 highway, though, is becoming as high as 25 for some folks!!!!!
One thing that hurts us is our preference/need for bigger vehicles. But that is a whole 'nother discussion.
#162
Doc
If you put a merged style x pipe at around 1.63 to 1.66 (based on assumptions of scale from pictures) times the average length of your primary header tubes back from the end of the primary tube (not collector) that will produce the best volumetric pulse efficency AND produce a nice exhaust note rarely heard on a domestic engine.
Something like the below is very easy to incorporate into a parallel type tube arrangment.
http://www.summitracing.com/parts/MPE-10791/
#164
I can't help but wonder what kind of market there may be for a flat crank for some of the more popular domestic small blocks. Imagine a 944 sounding like a Ferrari (yes, VE will go up, too). That'd be SWEET.
#165
Small Business Partner
+1 I've dreamed of a flat-crank option for an LSx for years now... Then stuff it into an MG MGB
