Which bolt in roll bar.
Looking at race autopower bolt in bar. ? bolt in ok to meet most standards ? where do the mounting points end up in the car ? anyone have a link to an old thread with pics?
what standards are you trying to meet? I run my Redline bolt in bar w/ PCA HPDE and it works great, bolts to the rear seatbelt locations. Autopower is a nice bar but you must drill some holes.
I have a Safety Devices cage, its pretty nice. Any bolt in cage is going to require drilling holes, only the Redline rollbar (which I also have) uses stock holes.
If anyone wants to buy my 6 point Safety Deivces cage, let me know. I think I am going to get out of the game shortly.
xsocaltrashx (02-16-2020)
I have an Autopower bolt in bar. I am happy with it, but only do DE and no bar is required. I do not know what rules you will be dealing with. I got the optional diagonal brace and harness bar and recommend both. It is necessary to drill three holes for each of four mounting points. Two mounting points are on the floor behind the front seats and two are on the wheel wells. I took alot of time to cut out enough carpet to allow drilling holes without runs, but left enough that no holes or cutting were visible. It takes me a long time to do anything. I am sure it would be stronger if it were not over carpet, but I think it is strong enough for my level. You do loose the back seat with the diagonal brace or harness bar. You can have the seat back up or down. Once the bar is in you can not change it. It is necessary to take out seats to install. The drivers I did not remove from the car, but unbolted and pushed forward. I squeezed the bar in from the passenger side to install and almost had enough room. I broke the windshield. Later I removed it from a 944na and put in a Turbo. It worked much better going out/in the back hatch than the passenger door. There are backing plates for the mounting points and the ones for the wheel wells were not the right shape. I hammered them and my thumb to get the right contour.
Norm
Norm
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I got to see a 968 with a squashed autopower roll cage at the club race at Watkins Glen last year….the drivers helmet was damaged….he was lucky to not be paralyzed or worse.
There is a thread on that somewhere….
If you think you really need a cage – get a real cage welded in….please….
I got to see a 968 with a squashed autopower roll cage at the club race at Watkins Glen last year….the drivers helmet was damaged….he was lucky to not be paralyzed or worse. There is a thread on that somewhere…. If you think you really need a cage – get a real cage welded in….please….
The driver in question was only saved because of tubes he had welded in to meet Club Race rules. The stock cage is illegal for most racing series as delivered. Even then, the roof came down far enough to compress his head into his chest and severely restrict his airway. Fortunately, he was able to undo his belts before he passed out.
Here's a nice example of a roll bar that bolted to the floor, and its effectiveness. Look closely, and you can see some of the bar, and how strong the floor is.
Keep my number for the Demon Yellow if you completely loose your mind.
I am saving cash for a summer trip to Europe, yes the Porsche factory is on the list, But I can't let the Yellow Demon disappear!!
I have someone that can weld very well. I can drill pretty good. Cool thing about bolt in is it might be nice to be able to remove it if need be. I understand that welding might be stronger and drilling large holes in the body is not something i want to do to my car. thank you for the replys. I think the autopower race bar welded in sounds like the way to go.
The problem with the "bolt in" bars isn't that they bolt in, it's *where* they bolt in. They're using the weakest parts of the car, the floorpan and the wheel wells, both of which are single sided steel.
Take a look at how the autopower rollbar punched through the floor of that mustang that rolled at Hallett and see if you're comfortable with that. I know I'm not...
Har!
