dual factory oil coolers
#46
My factory oil pressure gauge is pegged at just below 5 bar hot at anything above 2,500-3,000 RPM, same as before the extra cooler. My engine has 130K miles and has never been apart.
At idle I see 3 bar warm on the street, same as before. Hot coming off track, it is now around 2 bar at idle, whereas before it would be barely above 1. Once again I'm sure most of this is due to cooler oil, but part of it could be attributed to changing oil type at the same time. I wish I could have done it in stages, but didn't have time.
Your observation about pressure drop through the system once the oil thermostat opens makes sense, but I haven't seen any difference since installing the 2nd cooler.
Re the cooling temps, I wonder if your condenser was really blocking the airflow. I haven't had any cooling issues at all and didn't notice any water temp change with the oil cooler.
Once again, I wish that I could have done it in stages and compared results. Maybe the next person who does this mod (and somehow keeps A/C) and tracks it on a hot day could monitor the results and post them.
#48
Thanks for the notes Chris.
I'm seeing about 4bar hot on Mobil 1 15/50. I'm wondering if it's getting time for a bottom end rebuild. 190k, rod bearings done at 140k.
#49
For those who were wondering, I just looked under the '89 we have in the shop, and it uses the same condenser/hoses as the '86. In fact, according to PET, even the 968 uses the same part #s for the condenser and hoses.
So, anyone hoping to keep the factory A/C and mount an additional factory oil cooler in that location would have to space it out from the radiator frame like I did, and fill in that space and/or block it off so that no air gets between the 2. As previously mentioned, this also eliminates the need to move/modify the headlight wiring harness.
#50
I'll just chime in on this, haven't been following it a lot, but we see 2.0 to 2.5 at hot idle after a track session, max oil temp seen is 220-230 but that's hot ambient and no session in between my drive or Jim's drive, ie we try to schedule the car to get a rest between white and blue sessions to cool it down; green drives between white and blue solo sessions.
#52
Bret - can you help with the following?
What are your hot, high RPM oil pressures?
What brand and weight oil are you running?
How many miles on your bottom end?
Was the last (if any) rebuild rods only or rods and mains?
Where are you measuring your oil temp?
This should help with various comparisons.
Cheers!
Jeff
Cheers!
Jeff
#53
disclaimer, this is from old engine, new one has not been on the track yet but everything is the same and all have been cleaned.
What are your hot, high RPM oil pressures? 5 bar
What brand and weight oil are you running? VR-1 Valvoline
How many miles on your bottom end? It was 4 years, avg 6 events, but car got double duty with two drivers on weekends
Was the last (if any) rebuild rods only or rods and mains? All were new when we built it
Where are you measuring your oil temp? at the turbo drain fitting so our laser has said that's 10 deg higher than the lines we measured at the inlet of the first cooler.
Cheers!
Jeff
Cheers!
Jeff
