Front main seal - why does it still leak?
What I ended up doing was using the pulley gear turned around and stacked one of the old seals between the new seal and the pulley. That made it drive it in from around the edge instead of against the flat face of the new seal. I also got the new seal started first which was the hardest part. I think I only had it started about a mm into the bore.
