Wossener V's J&E ????
Old 11-12-2009, 09:03 AM
Thom
Thom's Avatar
Originally Posted by Chris White
interesting to note that the stock pistons are a high silicone alloy (like the 2618 alloy). They seem to survive past 18 psi for a lot of the listers...
What are the "old" Mahle/Andial 104.5mm pistons made of?
I would guess Mahle specced them the same as the stock 100mm pistons?
Old 11-12-2009, 09:36 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
That would be my assumption based on the recommended skirt clearance.
Old 11-12-2009, 10:22 AM
Duke
Duke's Avatar
Now I'm confused, I think you mean stock are more like the 4032?
Old 11-12-2009, 10:28 AM
Chris White
Rennlist Small
Business Sponsor
Sorry, yes! 4032...
Old 12-02-2009, 06:36 PM
Kpoeltl
Kpoeltl's Avatar
I was just made aware of this thread and wanted to post a bit of information. For those of you who don't know me, my name is Karl Poeltl and I run Racer's Edge and we sell Wossner pistons among many other things. We do a lot of custom piston design work with customers to make sure they get what they want. Our(Wossner's) forgings are made for a "slipper" or "semi-slipper" design piston as opposed to a fully round design.
In a full race high boost situation a fully round style piston like the stock 944 Turbo pistons works great and was a great design choice when these engines were first designed and made. But technology has improved and we now have 600 HP 1.3 liter engines running a semi slipper style piston design, and it is this slipper design, not a fully round design, we use for 944's.
4032 pistons have better wear characteristics in an extended use application as 4032 is the most durable material for longevity in a high performance boosted application. Where 4032 noticeably excels in “performance” is that the 4032 piston need less clearance and do not have the knocking at start up commonly associated with a 2618 material piston.
2618 when placed under a load when the engine is not to operating temp seems to hold the shape better which makes them popular in very high boost drag race applications as those engines don't run very long before they are run hard and then shut off . For a max boost drag race application the 2618 is a great choice as the pistons can also be made a few grams lighter (not much however a little lighter).
I hope this helps regarding the pros and cons of both materials commonly used in today’s High performance engines. By the way, most of the OEM premium forged pistons are made from a material that is closer to 4032 than 2618.
Karl Poeltl
Racer's Edge Inc.
865-862-5262 voice
865-862-5271 fax
Old 12-02-2009, 11:36 PM
Charles A. Toupin
Charles A. Toupin's Avatar
I also heard about Arias pistons, or something like that. How are they? Did anybody ever used them?
Tx
C.
Old 12-03-2009, 12:08 AM
95ONE
95ONE's Avatar
Charles, I've never had good luck with those in the high boost Honda scenario.
Old 12-03-2009, 04:17 AM
mikey_audiogeek
mikey_audiogeek's Avatar
When I was crewing 15 years ago, our engine builder used to refer to Arias pistons as "block knockers". The pistons would stay mint but wear out the (cast iron) block pretty quick due to the clearance, they were a high clearance design. Strong, but.
Mike
Old 12-03-2009, 10:20 AM
Charles A. Toupin
Thanks Guy!
How long is it to get a set of stock pistons from Wossner?
C.
Old 12-03-2009, 10:32 AM
Kpoeltl
Kpoeltl's Avatar
Wossner can deliver anywhere from 2-5 weeks. We average about 3.5 - 4 weeks,... it is completely dependent on production backlog.
Old 12-03-2009, 10:54 AM
Charles A. Toupin
So I understand that you don't keep in-stock inventory of that kind of pistons.
c.
Old 12-03-2009, 12:00 PM
Charles A. Toupin
I'm still a bit confused about the Arias pistons.
I went trought the site a little bit and I found that there were sets of pistons designed by Tom Charlesworth for 944/951 and made by Arias.
I understand that Mr. Charlesworth is very knowledgeable and that some rennlisters used these pistons and did not have any problems with them.
Any opinion on these specific pistons?
C.
Old 12-03-2009, 12:11 PM
95ONE
95ONE's Avatar
Im pretty sure that I just read a post in the past few months that actually commented on how there were multiple problems with those pistons. maybe do a search.. I just can't remember if it was these exact pistons.
Old 12-03-2009, 03:06 PM
Charles A. Toupin
I did another search and I did not find anything wrong with those Charlesworth pistons. There is one guy who blew his freshly rebuilted engine and had those pistons, but who knows if it's the pistons or anything else. I think, maybe I'm wrong, that you have to be an extremely well qualified mechanic to be able to blame a set of pistons for a mechanical failure.
Actually, I will have to rebuild my engine this winter and there is one guy in Montreal who has a brand new set of them. They are coated too. And he has the steel sleeved block to with them. So it may be a possibility for me. Since I want a bulletproof, no hassle engine, I want to make sure I buy the good stuff, if I go this way. And since I'm running on a shoestring budget, the engine must not blow for the next 3 seasons at least.
Tx.
C.
Old 12-03-2009, 04:53 PM
Fishey
Fishey's Avatar
We had a set of failed 911 J&E's so this is the 2nd time the motor has come apart for crappy manufacturing by aftermarket sources.
Quick Reply: Wossener V's J&E ????
