DIY Tuning walk-through (TunerPro)
Small Business Partner
Drive-by provocation guy
Wow!
So we now have stand alone tuning for less than $200?????
Couple questions:
A. So on start up once the Ostrich is pluged in and running Tuner, our car will be running on bone stock fuel/timing maps correct?
B. Those of us with bigger MAF, injectors, etc. will have to tune from scratch and will our car even start or run on stock MAPS if running much bigger injectors, etc.?
C. Is it possible to save a "base tune" so in case things get way off the mark you can easily switch back to a basline without re tuning all over again?
D. Is there any way to load/save our after market chip tune into Tuner as a baseline?
Couple questions:
Also, is the knock counter available to buy or only DIY make?
What is an acceptable knock count or threshhold when adding timing? I.e. at what knock count do you need to stop adding or slightly pull some timing back out?
Wow!
Couple questions:
yes
yes before you edit the bin just go file save as and change the name of the bin and save it.
Couple questions:
yes
First thank you Rogue_Ant.
Then I have the following questions:
Like Todd911K asked is the Knock counter a DIY?
Would this be easy to tune if you are running MAF. I'm already tired of fixing this car so I don't want to blow anything else. Any Risk takers for the MAF setup?
Brian
86 951
heres a link to a diy knock counter for right about 20
https://rennlist.com/forums/944-turb...-pictures.html
From what it says on the Moates web page it looks like the Moates burn2 will only read the 2732a (our 24 pin chip) and not burn it. I have a BK Precision 848 (ebay find) and it works great. It reads and burns. Also get a good eprom eraser. I bought a new one, the BK Precision 850. The eraser is a UV light that formats or "sets" the chip. If you get a used eraser it will probably need a new bulb....
Brian
86 951
Brian
86 951
Check the thread here:
Click Me
I suggest tuning for less then 5counts per gear @ WOT. Ultimately, I tune for less then 2counts per gear @ WOT.
Check my response above.
The closed-loop RPM adjustment should be on the left in TunerPro (thrid one down under the constant/scalers section):
My car is a constant test bed. And I run E85 which is much more forgiving then gasoline.
-Rogue
So for all that have an aftermarket chip and want to build on that, we need the reader and the ncan save that mapping as a baseline, assuming the aftermarke chip will work with Tuner Pro, correct?
I assume that even from stock mapping, it is not much work to get it tuned to run with aftermarket parts as you just input the desired a/f ratio and it should be close to that?
i.e. from your example of 0 psi/load being 14.5:1 and then richen just like normal all the way to 11.5:1 by 12+ psi?
it is not trial and error like a piggyback, just input desired a/f ratio (12:1) and you are on your way?
And if so, then stock timing could mostly be retained for part throttle/idle and only pull out timing in the upperload/boost cells?
is there an adjustment for injector duty cycle?
Sorry for all the quesitons.
PM me.
Yes, the FQS is essentially a 'global fuel scaler'. By inputting a larger injector number in the FQS, you effectively lower the injector duty cycle.
No worries
-Rogue
I don't own MaxTune, so I can't say for certain. I assume so - but am not about to make any promises.
The overboost map:
All of the tables and constants in TunerPro tell you what it is, make sure the Item Comments window is displayed
-Rogue
The overboost map:
This is the (calculated) boost curve that the dme looks at to determine oferboost. If boost is above this, then the DME will cut fuel (overboost). Raise this number to allow for more boost.
-Rogue
they dont offer the maxtronic any more, unless you buy one used. youll be getting an ostrich 2.0
