Et voilà... another 3.0 8V hits the road
Old 07-28-2012, 11:10 PM
  #91
333pg333
333pg333's Avatar
Your head is a stock 2.7L yes Thom? Not that cfm is everything, but I wonder what the actual stats are of these heads?
From what I've read the GTX3076 has a broad enough range to be a direct replacement for the older GT35R anyway, so it should be a good choice for this motor.
Haven't you also changed your intake Thom?
Old 07-29-2012, 02:05 PM
  #92
95ONE
95ONE's Avatar
Originally Posted by Paulyy
So you've put in a GTX3076R? on your 3.0?
What size a/r? and how do you like it from what ever your had previously?
and why didn't you go for the larger GTX3582R ?
Pauly, the GTX3076R should be able to hit 500whp with no problem. Instant spool on that motor. repating. 500whp with instant spool. Do you need more than 500whp!?
Old 07-30-2012, 06:39 AM
  #93
Paulyy
Professional Hoon
Paulyy's Avatar
I can't see any problem reaching 500 whp.
I guess since it's an 8v there's no real need in a larger turbo. If it was a 16v i'd most likely consider getting a GTX3582R just to maximize the efficiency with the 16v head & compressor.
Old 07-30-2012, 08:40 AM
  #94
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
'Need' maybe not......'Want' - always!
Quick Reply: Et voilà... another 3.0 8V hits the road
