Process - How to set boost level
Has anybody seen a simple to use process for setting boost.
The IDIOT in me say's to turn the manual boost control in very small increments until the stock dash boost meter is close to maximum. It just can't work like that ..can somebody point me in the right direction? |
Don't rely on the stock gauge...get an aftermarket gauge such as this...http://www.summitracing.com/parts/ATM-4306/ you can spend more, just a sample. The stock gauge is more than likely off.
Using a boost gauge other than the stock one, do pull in 3rd gear
and see what your max boost is. The learning curve is figuring out how many turns is 1psi on your setup. With a tial 38mm in dual port and the LR black knob it's about 1 turn per psi on my car. Depending on your setup you may get boost creep in higher gears. Therefore set your boost in 4th gear or atleast check and see what it goes up to. |
Originally Posted by Fluidplay
(Post 6830360)
Originally Posted by Techno Duck
(Post 6830571)
and see what your max boost is. The learning curve is figuring out how many turns is 1psi on your setup. With a tial 38mm in dual port and the LR black knob it's about 1 turn per psi on my car. Depending on your setup you may get boost creep in higher gears. Therefore set your boost in 4th gear or atleast check and see what it goes up to. to the OP, install an aftermarket gauge, run through all your gears and see where your highest boost shows... adjust from there... If I set my LR black knob for 13 PSI in 3rd I hit 16PSI in 4th and 5th... so I adjust in 4th not 3rd... it will differ from car to car, and driver to driver and course to course... it is largely driven by load on the engine so try for level ground... Your stock boost gauge can be WAY off... mine is as are most others... |
yeah, I'm about the same as you John - maybe a quarter turn or so for me.
I set mine in 3rd because I don't want to have to pay attention to the boost gauge there since I'm in 3rd a lot more than I am in 4th. When you aren't sure - just don't floor it...creep it up and once you think you are a few PSI away from where you want to max out - then do a run and make sure your foot is on the floor to lock it in. There's no scientific way to do this - you'll have variance in how many turns on your LBC (as noted in this thread already) so no one can tell you to give it three cranks and you're at 15PSI. Definitely recommend the aftermarket boost gauge though to know for sure. Frankly, anything is better and probably more accurate than the stock gauge and they are easy to install. |
I was always impressed with the simple AccuBoost controller I had on the black car. I could set it in 3rd, 4th, or 5th and it would always hold the same mark except at much higher altitudes. Never trust the OE gauge and try to run your signal source directly off a manifold fitting rather than the KLR tube if you can.
Originally Posted by JohnKoaWood
(Post 6830618)
What he said... my in dash maxes out at approximately 13 PSI... but my AM gauge and MAP sensor both indicate true...
1 turn per PSI...dude... I get like 1/8 turn per PSI... wonder why such a big variation... to the OP, install an aftermarket gauge, run through all your gears and see where your highest boost shows... adjust from there... If I set my LR black knob for 13 PSI in 3rd I hit 16PSI in 4th and 5th... so I adjust in 4th not 3rd... it will differ from car to car, and driver to driver and course to course... it is largely driven by load on the engine so try for level ground... Your stock boost gauge can be WAY off... mine is as are most others... |
Originally Posted by choinga
(Post 6830920)
I set mine in 3rd because I don't want to have to pay attention to the boost gauge there since I'm in 3rd a lot more than I am in 4th. When you aren't sure - just don't floor it...creep it up and once you think you are a few PSI away from where you want to max out - then do a run and make sure your foot is on the floor to lock it in. There's no scientific way to do this - you'll have variance in how many turns on your LBC (as noted in this thread already) so no one can tell you to give it three cranks and you're at 15PSI. Definitely recommend the aftermarket boost gauge though to know for sure. Frankly, anything is better and probably more accurate than the stock gauge and they are easy to install. I want a EBC soooo bad, but have bigger fish to fry first... If I go full stand alone this winter, I'll use it for boost control... |
(Post 6830618)
EBC is nice. I had some issues getting mine dialed in at first, but once you get it set, raising or lowering the boost is easy. My AEM allows an A and B setting - I keep A for normal driving (13psi) and B is set for a little more boost for the weekends (14.5psi). http://gallery.me.com/curt.phillips/...12419747270001 |
thanks!
Hey guys thanks for the guidance on that one.. I'll report back once I make my way from a dyno.. :evilgrin:
Originally Posted by KuHL 951
(Post 6830943)
Yep on my Lindsey BC I was at 12.5 psi at 12:00 at 12:30 I am at 15.2. Working my way back up to 18.
I turned mine all the way up then slowly turned it down to get the setting I wanted at wide open throttle
Originally Posted by dillon410021
(Post 6835238)
Originally Posted by ModdedEverything951S
(Post 6835430)
Not always the best approach, it can put you into an overboost situation and that can be disastrous.
