Build your own Maf kit
#61
Small Business Partner
I'll give a more detalied response when I get home tonight.
#62
Tuner Pro has to use the Ostrich 2.0 ROM tracing to get it to function correctly... MaxTune only needs the base 4K BIN to build an entire DME chip immage from, and it is one button...
I have been running the MaxTune SW for a few months, and am really likeing it, and Russell has been great..
If $250 is out of bounds, YES tunerpro will work, but the DME code will still need more work to coorelate the load demand to the MAF as opposed the AFM (AFM is measuring volume, MAF is measuring MASS.. you will also need intake temp, unless your MAF has it built in, AND voltage correction as the MAF reads differently on the output than the AFM does...)
I am running a Scivision MAF (well, right now my AFM is in awaiting a replacement harness) and using MaxTune for my maps, the MAF comes with a fixed value translator to go from the MAF to a AFM syle signal for the DME... MaxTune allows modification of the fuel and timing maps, and I have also been toying with my temp correction and FQS values..but that is me...
Rouge has been decompiling the DME code, to modify the way the code works... this is whole different level of effort that I enjoyed once upon a time, but no longer enjoy doing, now I want plug in, hit a few buttons, up an running... DIY MAF is deffinitely NOT plug in and go...
Rogue, Go for it, open source is fun, untill someone asks "what did I do wrong, my motor blew up"... open source for an I-Phone is cool, no real harm done...open source on a car can be dangerous, or costly...
To those who have only one car, be careful of what you do to it...please,
or at least let me have dibs on the pieces left over if it goes wrong...
#64
Now lets say the you are using a piggy-back to compensate for larger injectors. In order to get the correct AFR, the piggy-back lowers the airflow voltage signal to the DME. The DME uses this new signal for its load calculation.
Lets say by using a PB to adjust for larger injectors, it changes the load calculation ~10%. This can have a significant change on ignition timing advance. For example, look at the difference in timing advance between the ~34% load and the ~24% load. As much as 7degrees! And that is only scaling the load value ~10%, imagine if you are scaling for very large injectors...
#65
-Rogue
#68
-Rogue
#70
Only difference between my setup and this pic is I also have an SFR J pipe, and K&N cone filter mounted behind my driver side head light...
The harness shown is the non-adjustable piggyback, it is also the component that failed on mine, I have my AFM installed and am waiting for my replacement harness to arrive, it shipped from Germany yesterday, so it should arrive next week some time...
It is nice in that it is doing what I want it to do for now, but if I ever get around to my winter projects... I will be going a different route all together...
#72
That having been said...
I for one LOVE the idea of opening up the DIY tuning on these cars to the average bear... Do it, but be prepared for SOMEONE to come banging on your door asking for help...
#74
from what ive seen both of you are more than willing to help others out. and im already knocking as im getting more in depthe with this car than i have in the past. ive usedh safc's but thats as far as ive gone.
#75
