Blue Brake Hose going to Clutch Master
Need to replace the "Blue" fiber wrapped hose that goes from the brake fluid reservoir to the clutch master cylinder. Do I have to get a factory part, or are there other options that might be cheaper / more readily available ?
Thanks --- Tom
Thanks --- Tom
Paragon has some. I believe it is either 3 or 6 dollars a foot. I just replaced the brake resevoir and clutch hose on my S2.
I bought two feet to be on the safe side.
