Clutch replacement pictorial
#31
Try and get a puller if possible, it will make life alot easier. I am a firm believer in the right tool for the job, but i was in a bind and unfortunatley the slidehammer i had did not fit.
Anyhow, any bolt long enough to get the vice grips far enough away from the engine to give you room to give it a solid shot with a hammer will be enough. I used an old long turbo mounting bolt which i happened to have in my tool box. Use a flat washer on the bolt small enough to fit through the ID of the bearing race and a vice grips on the threaded end of the bolt. Hammer the vicegrips a few times and it will pull the bearing out.
#32
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Just wondering (since I'm about to remove the RMS -- replaced the pilot bearing today) what was so tricky about this? It _looks_ like it should be easy, given the "screwdriver cutout" in the housing to get access to dig into the seal with. But obviously not... what's the story?
#33
That seal is really in there good.. a flat tip screwdriver is really not up to the task, nor was a pretty heavy duty right angle pick i used. A seal puller is a must for this part so you also avoid damaging the crank or sealing surface.
#34
Great work Jon!
Since you now have a lightened flywheel, you may want to change your timing belt a little more often.
Lightweight flywheels on 4-cyl cars put more stress on the timing drive due to the torque impulses. This ain't just a theory, I've worked on racecars where reinstating a stock weight flywheel was the best way to get the timing belt or chain to survive. Quite often, the failure happened when idling.
#36
You will need the turbo specific bell housing, clutch fork, release bearing, clutch, pressure plate flywheel... i think you may need the turbo starter ring gear also.
