TIP: Somebody should take a GM LS1 computer and run in it on a 951
#46
#47
Instead of a LSx computer, how about the one for the Cobalt SS Turbo, Solstice Turbo or Sky Turbo? HP Tuners works with them too. You could start with a factory wire harness, sensors, coil packs already set up for a 4 cylinder car.
#48
New guy here but know quite a bit on the LS stuff...
The LS2 would be the way to go by far between it and the LS1 computer... I think there is a way to get around the electronic throttle body also.
If the new Coblat turbo SS or Solstice ect ect computer has the same peramiters then I am sure it would be less work but getting one of those comptuers cheap would be hard. I know Speartech to retrofits and will pretty much build any harness/computer you could dream of but if it was me and I had the money I would see if you could get a Big Stuff 3 for one of these cars.... those make even the LS2 computers look like a joke....
#51
Rennlist Junkie Forever
Anybody do this yet?
GM LS1 computers are $80 on ebay and have a ton of configuration capabilities.
I read somewhere that a couple of people had used these on 4 cylinders so I know it can be done.
Cheap, reliable, very configurable.
Someone needs to get the crank and cam trigger wheels made and set one up (and no more distributor.... individual coils-per-cylinder).
TonyG
TonyG
#52
So yeah it will work.
The cool thing is that you can put the cam sensor on the end of the cam where the distributor now sits (I think Clewett a cam sensor bolt on package) since the GM setup uses individual coils (again... very inexpensive used).
If I was still running the turbo 4 this is the setup I'd be running for sure.
Plus... there are a million GM performance shops with dynos that can tune the thing very easily using HP Tuners.
$80 on ebay. Plus a cam and crank trigger and a set of used coil packs from a LS1. I'm sure the entire setup would be under $400.
TonyG
#53
Rainman
I was planning on doing the same thing, but with a ford computer and the tweecer rt setup. I had the tweecer set up on my old mustang, and got real familular with all the different variables that can be configured.
You could set it up for 2-12 cylinders, any firing order, displacement, sequential or batch fire injection, ignition style, boost control, knock control. also it had injector timing controls so you can fine tune your injectors to match any cam profile.
The computers are dirt cheap, used harnesses are dirt cheap as is the tweecer rt, and it even data logs to boot.
I might look into the ls computers also Tony.
Semper fi
Semper fi
which ECU is easier to work with as a "DIY tuner", the GM LS unit or one of the Ford pieces?
either one has the same amount of "pro help" available if needed, both equally common and capable.
depending on year both let you have coil on/near plug.
but the ford stuff has been around a little longer (early 90s with the introduction of the Mod motor) so early stuff might be easier to wire up to the car, but itd be cool to have OBDII
#55
Why would you need to do such thing? There are ECU's available that plug right into 951 stock DME and KLR harness (use all sensors, including knock) and drive better than factory ECU:
If this post is not allowed, please remove it..
#57
Why would you need to do such thing? There are ECU's available that plug right into 951 stock DME and KLR harness (use all sensors, including knock) and drive better than factory ECU: VEMS Plug and Play ECU for Porsche 944 Turbo - YouTube
A late model OEM computer is hard to beat.
That said... I threw it out there as a suggestion as to what I would be using (or tying to use) if I were still using a Porsche turbo 4 engine.
TonyG
#58
I think this ECU scheme is brilliant. Who is capable and can put together a package? The only challenges appear to be mechanical (sensor set-up), and electronic (harness). Perhaps two capable guys could collaborate to address these issues and I would imagine lots of people would benefit. This is a good example of the value of RL!
#59
The wiring harness is easy.
TonyG
#60
What about the knock control part? Would you still keep the KLR or do the GM units have this built in?
