Brake Rotor Thickness
Old 02-27-2009, 05:17 PM
beefey
beefey's Avatar
Default Brake Rotor Thickness
I'm machining my brake rotors today I am wondering If I'm looking at the right spec... In the manual it doesnt seem to have a Turbo column but please correct me if I'm wrong but the S2 shares the same brakes as the turbo right? If not where do I find the specs? Is it in the turbo supplement? This is a 88' 944 turbo.
I have attached the link to the PDF where i'm getting this info.
http://www.frontiernet.net/~burlroof/Brake%20Specs.pdf
Thanks,
Beefey
Old 02-27-2009, 05:53 PM
shiners780
shiners780's Avatar
Specs for '88 951 are:
Front
New 28mm
Min 26mm
Rear
New 24mm
Min 22mm
Old 02-27-2009, 11:26 PM
Spidey944
Spidey944's Avatar
Brake Rotor Specifications
Front
Diameter:
944 S 282.5 mm
944 S2 & 944 Turbo - 162 kW 298 mm
944 Turbo - 184 kW 304 mm
Minimum thickness
New:
944 S 20.5 mm
944 S2 & 944 Turbo - 162 kW 28 mm
944 Turbo - 184 kW 32 mm
Wear limit:
944 S 18.5 mm
944 S2 & 944 Turbo - 162 kW 26 mm
944 Turbo - 184 kW 30 mm
Thickness variation: 0.02mm
Maximum lateral runout:
Wheel hub 0.05 mm
Brake disc 0.05 mm
Brake disc - when installed 0.1 mm
Rear
Diameter:
944 S 289 mm
944 S2 & 944 Turbo - 162 kW/184 kW 299 mm
Minimum thickness
New:
944 S 20 mm
944 S2 & 944 Turbo - 162 kW/184 kW 24 mm
Wear limit:
944 S 18.6 mm
944 S2 & 944 Turbo - 162 kW/184 kW 22 mm
Thickness variation: 0.02 mm
Wheel hub 0.05 mm
Brake disc 0.05 mm
Quick Reply: Brake Rotor Thickness
